I have a DVD on which the main movie is all in one title set, but is split (arbitrarily it seems) into several PGCs, as follows:
PGC1 - 20:05
PGC2 - 05:02
PGC3 - 53:02
PGC4 - 07:46
PGC5 - 03:22 (trailer)
Within PGCDemux, I can select to demux by VOB ID and this then gives me the full movie. However, when I go into VOB Blanker, I can only replace by PGC, not VOB ID. Is there any way to replace by VOB ID? I tried doing it for each PGC and I ended up with audio out of sync in the third and fourth PGCs.
I am adding subtitles FWIW. I've worked on many DVDs but have never come across this problem before.
No, and I also consider that a drawback as I've wanted to replace VOB IDs before.
Should be pretty easy to fix. They're off by the same amount all the way through, aren't they? Did you check for a delay when demuxing?I tried doing it for each PGC and I ended up with audio out of sync in the third and fourth PGCs. -
Bizarrely, apart from the first PGC, PGCDemux shows the other PGCs as not having an audio stream. But, when I demuxed them, the audio was there. Is there any other way to check for an audio delay?Should be pretty easy to fix. They're off by the same amount all the way through, aren't they? Did you check for a delay when demuxing?
Thanks for the reply
Audioless PGCs are often indicative of an incomplete decrypt. There is an/are unreferenced and audioless cell(s) before you get to the main video. With the complete DVD already on the hard drive I think I'd run the VOBs through FixVTS to try and remove those cells, and if it works your PGCs should now show some audio.
Even so, it's easy enough to find out the delay after the fact, remove it from the audio using DelayCut, and then reauthor the PGCs using Muxman or whatever your authoring program is before doing the final replace step in VobBlanker.
How to add your own subtitle to DVD (keep menu, multi-pgc)
By bluedha in forum User guidesReplies: 339Last Post: 10th Oct 2013, 21:11 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 19:31 -
Print DVD Information (VTS - PGC)
By dw-wizard in forum DVD RippingReplies: 0Last Post: 27th Sep 2010, 15:54 -
Weird DVD structure (can't rip)
By jsbenson in forum DVD RippingReplies: 7Last Post: 25th Jul 2010, 22:45 -
rip DVD content by VTS, instead of PGC?
By lordsmurf in forum DVD RippingReplies: 7Last Post: 28th May 2009, 11:35
