What is the best device for using your tv as a monitor with a wireless connection? Like to be able to stream things like netflix , surf the net and watch tv shows from the tv network websites.
Thanks for your time
Results 1 to 12 of 12
bluegrassdan, I have tried all of them I could find, and I returned all of them. I now just use a HDMI cable between my laptop and TV. It's a much better picture being hard cabled in direct. Sorry, I can't recommend any of them.
Re-reading your post, maybe I mis-understood your question and gave the wrong answer. -
bluegrassdan, I fully understand what you're looking for as I'm looking for the exact same thing and couldn't find anything. I have a desktop which I can't just 'drag' from one room to the living room where my LG tv is located and of course I can't connect them via an HDMI cable, right..? I'm sure there's some kind of a solution for that but the problem is that I'm probably lacking the right terminology while searching on google...I'd love to know where I can find a solution to that.
Huh! Me too!...I'm turning over the web, hunting it out....guess they don't have a name for it yet,...I gotta WD media player an early one connected to an external hard drive, should have got the later model with the network connection plug...maybe??
No idea how well this would work but you might look into hdmi over ethernet if you have the option to run long cable runs of cat5
Donadagohvi (Cherokee for "Until we meet again") -
Hi there, I am new to this site, and looking for the same thing...... Wirelessly streaming video etc from my wifi enabled laptop, to my TV, but I have an internet linked sony bravia tv, and still cant find a way of linking the two! You would have thought that you could use your N series router to communicate between them!
I am not the brightest with computers', so if anyone has any idea on how I can link the two for video playback, then please let me know!
Thanks in advance!
By the way, I am in the UK!
Does your Bravia have wifi built in? If not you can add wifi with something like
http://www.amazon.com/IOGEAR-Universal-Adapter-Office-GWU627/dp/B004UAKCS6/
http://www.amazon.com/NETGEAR-WNCE2001-Universal-Internet-Adapter/dp/B003KPBRRW/
http://www.amazon.com/TRENDnet-Wireless-Gaming-Adapter-TEW-647GA/dp/B0024G48VA/
If your TV will play video files via network shares use that. If it supports DLNA get some DNLA server software for the laptop.
DLNA servers:
http://www.rbgrn.net/content/21-how-to-choose-dlna-media-server-windows-mac-os-x-or-linux
http://www.playon.tv/index.php
Otherwise just get a wifi media player like the Western Digital WDTV Plus and add a USB wifi adapter.Last edited by jagabo; 24th Sep 2011 at 12:19.
My Sony Bravia TV does have built in wifi, and i can watch internet TV streamed straight from the internet anytime wirelessly, but only with the widgets pre-installed, like bbc iplayer and youtube etc, but I want to stream from my laptop. Is there any way I can stream through my wireless N series router, it's a D-link??????
I'm sure it cant be hard!
Thanks for the links, but they would not be suitable for the job I need it to do!
Kind Regards,
Craig!
Wireless Internet Connection Questions
By hech54 in forum ComputerReplies: 11Last Post: 28th Nov 2011, 10:38 -
Wireless PC to TV connection
By SpyJoe in forum ComputerReplies: 3Last Post: 28th Oct 2008, 10:24 -
Wireless Connection Problem
By StoneColdWhat in forum ComputerReplies: 4Last Post: 8th May 2008, 00:38 -
Easy way to know if someone else is sharing wireless connection?
By edong in forum ComputerReplies: 5Last Post: 18th Feb 2008, 20:37 -
Vista wireless connection issue.
By Poppa_Meth in forum ComputerReplies: 10Last Post: 26th Aug 2007, 13:23
