Installed latest registered version of SVCD2DVD which loads fine however when you start the encoding process the app crashes with the error messages:
Problem signature
Problem Event Name: APPCRASH
Application Name: ffmpeg.exe
Application Version: 0.0.0.0
Application Timestamp: 493ceb68
Fault Module Name: msvcrt.dll
Fault Module Version: 7.0.7600.16385
Fault Module Timestamp: 4a5bda6f
Exception Code: 40000015
Exception Offset: 00066804
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 49de
Additional Information 2: 49de6aef23e97c9a5c4161902f312889
Additional Information 3: 67e3
Additional Information 4: 67e3eaa5086dad4f65e07a5d8dbc91e1
and
Problem signature:
Application Name: SVCD2DVD.exe
Application Version: 2.5.5030.0
Application Timestamp: 00000031
Fault Module Name: DVDFolders.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4948cefd
Exception Code: c0000005
Exception Offset: 00004d2e
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Version: SVCD2DVD 2.5
Build: 2.5.5030.0
Type: System.AccessViolationException
Source: SVCD2DVD
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
I do not believe there is CPU overheating or bad memory issues. I have used other many other encoding programs over the past year without issue. Supporting this is the fact that HDTV2DVD seems to work properly whereas SVCD2DVD crashes. I've tried running the program as administrator as well as under the different WinXP and Vista compatibility modes, none of which all the program to work. Any ideas or suggestions? I would definitely like to use SVCD2DVD again. Thank you
Can post the log file associated with this run please? Help->Open Log Folder.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.5030.0
Executable: C:\Program Files (x86)\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2711635
Executable CreationTime: 1/28/2009 11:57:36 PM
Executable LastWriteTime: 7/9/2011 11:37:38 PM
Executable LastAccessTime: 7/9/2011 11:37:38 PM
************************* Operating System *************************
Operating System: Microsoft Windows 7 Professional
Service Pack: Service Pack 1
Version : 6.1.7601
Windows Directory : C:\Windows
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 5.99 GB
Free Physical Memory: 3.71 GB
Total Virtual Memory: 11.9 GB
Free Virtual Memory: 8.48 GB
***************************** Computer *****************************
Computer Manufacturer Name: System manufacturer
Computer Model: System Product Name
System Type: x64-based PC
Computer Name: UNIVERSE
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: Universe\Zeus
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz
Description: Intel64 Family 6 Model 23 Stepping 10
CPU Speed: 3.003GHz
CPU FSB: 333MHz
L2 Cache Size: 12.0 KB
12:56:39: Logical CPUs: 4
***************************** Time Zone ****************************
Time Zone: (UTC-08:00) Pacific Time (US & Canada)
****************************** VIDEO *******************************
Name: ATI Radeon HD 5570
Processor: ATI display adapter (0x68D9)
Mode: 1600 x 1200 x 4294967296 colors
Video Ram: 1.00 GB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 163 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 2.10 TB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="7/11/2011 12:56:39 PM" Filename="NONE">
<AssetSet>
<Asset ID="5b4f1ca2-d2d6-4f10-84e1-df5535e6c6c1" Path="D:\" Filename="Tron.ts" />
</AssetSet>
<DVDStructure>
<TitleSet Name="Tron" PostCmd="" MenuButtonType="0">
<MenuButton X1="0" Y1="0" X2="102" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">Tron</MenuButton>
<Title Name="Tron.ts" AssetID="5b4f1ca2-d2d6-4f10-84e1-df5535e6c6c1" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files (x86)\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="C:\Users\Zeus\Desktop" InitialDVDFolder="C:\Users\Zeus\Desktop" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="C:\Users\Zeus\Desktop" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="True" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="True" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="NONE" ImgBurnPath="C:\Program Files (x86)\ImgBurn\ImgBurn.exe" DVDDErase="False" DVDDClose="False" DVDDDontBurn="True" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 11.4 GB
file=D:\\Tron.ts
FormatName=mpegts
Num_Frames=160366
DurationInSecs=5351
Duration=01:29:10.8
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=1920
Height=1080
Standard=NTSC
BitRate=18447
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x34]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=384
Audio1Channels=6
HDTV2DVDMPG: 8000kbs
Leaving source audio alone.
Pass 1/2: Processing Tron.ts
Pass 2/2: Processing Tron.ts
12:56:39: HDTV2DVDMPG: done.
[Tron] 12:56:39: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[Tron] 12:56:39: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[Tron] 12:56:39: libavutil 49.12. 0 / 49.12. 0
[Tron] 12:56:39: libavcodec 52. 6. 0 / 52. 6. 0
[Tron] 12:56:39: libavformat 52.23. 1 / 52.23. 1
[Tron] 12:56:39: libavdevice 52. 1. 0 / 52. 1. 0
[Tron] 12:56:39: libswscale 0. 6. 1 / 0. 6. 1
[Tron] 12:56:39: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[Tron] 12:56:39: Input #0, mpegts, from 'D:\Tron.ts':
[Tron] 12:56:39: Duration: 01:29:10.88, start: 0.379044, bitrate: 18447 kb/s
[Tron] 12:56:39: Program 1
[Tron] 12:56:39: Stream #0.0[0x31]: Video: mpeg2video, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 65000 kb/s, 29.97 tb(r)
[Tron] 12:56:39: Stream #0.1[0x34](eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
[Tron] 12:56:39: Output #0, dvd, to 'D:\Tron_S2D.mpg':
[Tron] 12:56:39: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, pass 2, 8000 kb/s, 29.97 tb(c)
[Tron] 12:56:39: Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
[Tron] 12:56:39: Stream mapping:
[Tron] 12:56:39: Stream #0.0 -> #0.0
[Tron] 12:56:39: Stream #0.1 -> #0.1
[Tron] 12:56:39: [mpeg2video @ 0x3a09fe0]impossible bitrate constraints, this will fail
[Tron] 12:56:39: [mpeg2video @ 0x3a09fe0][lavc rc] Using all of requested bitrate is not necessary for this video with these parameters.
[Tron] 12:56:39: Press [q] to stop encoding
[Tron] 12:56:39: Assertion failed: picture_number<rcc->num_entries, file libavcodec/ratecontrol.c, line 698
[Tron] 12:56:39: This application has requested the Runtime to terminate it in an unusual way.
[Tron] 12:56:39: Please contact the application's support team for more information.
[Tron] 12:56:40: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[Tron] 12:56:40: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[Tron] 12:56:40: libavutil 49.12. 0 / 49.12. 0
[Tron] 12:56:40: libavcodec 52. 6. 0 / 52. 6. 0
[Tron] 12:56:40: libavformat 52.23. 1 / 52.23. 1
[Tron] 12:56:40: libavdevice 52. 1. 0 / 52. 1. 0
[Tron] 12:56:40: libswscale 0. 6. 1 / 0. 6. 1
[Tron] 12:56:40: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[Tron] 12:56:40: Input #0, mpegts, from 'D:\Tron.ts':
[Tron] 12:56:40: Duration: 01:29:10.88, start: 0.379044, bitrate: 18447 kb/s
[Tron] 12:56:40: Program 1
[Tron] 12:56:40: Stream #0.0[0x31]: Video: mpeg2video, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 65000 kb/s, 29.97 tb(r)
[Tron] 12:56:40: Stream #0.1[0x34](eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
[Tron] 12:56:40: Output #0, dvd, to 'NUL':
[Tron] 12:56:40: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, pass 1, 8000 kb/s, 29.97 tb(c)
[Tron] 12:56:40: Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
[Tron] 12:56:40: Stream mapping:
[Tron] 12:56:40: Stream #0.0 -> #0.0
[Tron] 12:56:40: Stream #0.1 -> #0.1
[Tron] 12:56:40: [mpeg2video @ 0x3a3ecc0]impossible bitrate constraints, this will fail
[Tron] 12:56:40: Press [q] to stop encoding
12:56:43: Done: Processing assets for DVD creation
Authoring DVD Folders
12:56:43: Creating TitleSet # 1
12:56:43: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
12:56:43: -->: DVDFolders creating VTS
12:56:43: -->: VTS 01
12:56:43:
DVD Folders: Processing D:\Tron_S2D.mpg...
12:56:43: -
Can you try a single pass rather than 2?
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 12:01 -
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 13:25 -
New Tool: HDTV2DVD
By ChrissyBoy in forum SVCD2DVD & VOB2MPGReplies: 270Last Post: 2nd Jul 2008, 22:05 -
HDTV2DVD (ffmpeg) crashes due to low memory
By thobhall in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Feb 2008, 07:39 -
SVCD2DVD 2.5.3100.0 Crashes
By boggle in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 11th Sep 2007, 03:34
