My most common authoring in the last few years is using MKV files that I burn in double-sided DVDs.
So the problems involved with it do not fit into DVD authoring or Bluray authoring. In this case I choose to ask this question here.
One of the problems I have to deal with is file size, which can never exceed 8Gb. And there are not too many variables I can adjust.
But one of them is audio file size, which I did also adjust when burning DVDs.
MKV files can't be read on too many Bluray players, and I bought my LG BD390 because it did. Unfortunately DTS files have to be sacrificed, because they are too large. So I always convert them to AC3/5.1 files, using Avisynth.
Then comes the kbs I want my AC3 file to be, maximum being 640. In DVDs, the maximum allowed was 448kbs.
No comes my question. There two intermediate kbs settings between 640 and 448 that I can choose: 512 and 576. Will any of those resolutions be accepted by the disc player?
My guess is they will, but I am not sure. My guess is also that the higher the resolution, the better the sound. So it should pay to use the higher kbs setting I could fit, is that so?
				Results 1 to 1 of 1
  DVD Authoring for MKV files and dts, ac3 supportBy anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2011, 17:32
  Stripping sections of MKV files to seperate smaller MKV filesBy spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 02:53
  authoring x264 .mkv files for Power Hour DVDBy TraceBusta in forum Authoring (DVD)Replies: 1Last Post: 1st May 2009, 16:51
  tsremux BluRay authoring from mkv files?By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 08:49
  Authoring a DVD using MKV filesBy cottage in forum Authoring (DVD)Replies: 5Last Post: 18th Jan 2008, 15:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
