i have an inspiron 2200 laptop and an old symphonic tv my laptop according to the manual has a video connector but no s video and my tv has a rca connection on it u know the red yellow white connector i want to hook my laptop to it so that i can play computer games with my friends hard to get around this small laptop i have a video connector to rca connector and a rca cable hooked from that to the tv but it is not working so am i doing something wrong i know that i can use my laptop to display on the tv so what do i need to make it work. Before anyone gets mad this might be posted somewhere here but i could not find it so any help you can give would be nice thanks![]()
Results 1 to 16 of 16
this is the connector that i have that goes from the computer to the tv and a male to male rca cord to accually hook to the tv
http://www.kiva.org/about -
Jibberish
What TV model number?
What laptop model number?
What laptop display chipset?
What do you mean by "video connector"?
NVidia says "TV Port"
I challenge you to get from a laptop to "RCA" composite TV off the VGA port.
Only known exception (to me) were certain proprietary very early ATI All-in Wonder cards that needed a proprietary VGA to analog component adapter.
There is a huge internet scam going on claiming VGA to whatever. Many even have footnotes explaining that these are unlikely to work. Prices are kept low so nobody will pay to return for credit. A near perfect crime.Last edited by edDV; 10th Jul 2011 at 01:34.
all i know is that my laptop is a inspiron 2200 and is 6 years old and my tv is an symphonic and is older then my laptop ad the manual calls the vga port a video connector but that is all i know
no the only connection that the tv has is rca u know the red white and white connections
For clarity, you might also consider the occasional period at the end of a sentence.
Model numbers confirm that the Symphonic TV only has composite video inputs and RCA stereo audio inputs, and your laptop only has a standard VGA port for video-out.
A VGA to RCA composite + S-video + RCA Stereo Audio cable will not work with your Dell laptop. The laptop cannot be configured to output S-video, composite video or stereo audio from its VGA port. An external box with electronics inside (known as a scan converter) is needed to go from computer-friendly VGA video output to CRT TV-friendly composite video input. You also need a mini-jack to RCA stereo cable to connect your laptop headphone jack to the TV for audio.
The laptop VGA would be set to output 640x480 or 600x800, depending on the scan converter and available laptop video settings. The laptop VGA port would connect to the scan converter's VGA input. The scan converter's RCA composite output would connect to the TV's RCA composite input. The mini-stereo speaker jack to RCA stereo cable would connect the laptop headphone port and the TV's RCA audio input.
Examples of VGA to composite scan converters:
http://www.amazon.com/KWorld-PC-TV-Scan-converter/dp/B0016VNYS2
http://www.amazon.com/gp/product/B003BVVYSM/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf...QP50DJ7FY56RSE
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=...seq=1&format=2
Example of Mini jack to RCA cable
http://www.amazon.com/Belkin-Audio-Cable-Splitter-1-Mini/dp/B00004Z5CP/ref=sr_1_2?s=el...0328947&sr=1-2Last edited by usually_quiet; 10th Jul 2011 at 19:23. Reason: wrote "output" when I should have written "input"
Can a Laptop with an Esata port Hook up to an Internal Bluray Writer?
By jbitakis in forum DVD & Blu-ray WritersReplies: 2Last Post: 10th Nov 2011, 21:16 -
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
Im looking to hook my laptop to my tv can I use vga to componet for this
By marionr26 in forum DVB / IPTVReplies: 35Last Post: 5th Feb 2010, 23:46 -
Looking to hook my laptop up to my 42 plasma
By marionr26 in forum Software PlayingReplies: 12Last Post: 26th Nov 2009, 17:35 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40
