Using MacTheRipper, I ripped a chapter. It had Directors commentary over it. I don't want this.
I've looked on other forums, and they say to Demux to solve this problem. But when I demux, I just get three AC3 files and one MV2 file.
I'm looking to get a VOB file, because then I can convert this to an MP4 file, which I can use.
What should I do?
OK, I've downloaded Handbrake, and there are no issues as far as audio is concerned when I rip the scene. So, that problem is solved.
However, it does NOT rip into MP4. When I select MP4 as the output format, the file name displayed in the "Destination" bar is .MV4, not MP4.
The MV4 file works fine in VLC player. But in iTunes and Quicktime it only plays sound, no vid.
I'm not bothered about the format, as long as it works in iMovie. But when I import it, it says "importing" and then does nothing.
I've tried changing the file name in Handbrake to .MP4, but this still does not work in iMovie. -
Ok, got it. If you want handbrake to make MP4 files, then you need to go into preferences and uncheck the box next to where it says "Use iPod/iTunes friendly (.m4v) file extension for MP4". Then, on the main of handbrake you need to go to the drop-down menu for Video Codec and make sure it's on "MPEG-4 (FFmpeg)". Then, once this is done, you must manually change the end of the file name to .mp4
This should work.
MP4 isn't as high quality as M4V, but it doesn't really matter - it's still very high quality, and, unlike M4V, CAN be used in iMovie.
Problem Solved.
Help with Avatar extended directors cut
By lordhutt in forum Blu-ray RippingReplies: 1Last Post: 5th Sep 2011, 18:47 -
tsMuxeR remove directors commentary 2012 for PS3
By xrsixturbo in forum Blu-ray RippingReplies: 3Last Post: 22nd Jul 2010, 21:55 -
Directors Commentary - How to Remove
By jah711 in forum Blu-ray RippingReplies: 12Last Post: 26th Feb 2009, 23:43 -
Directors cut/Commentary backup Only
By jah711 in forum Blu-ray RippingReplies: 0Last Post: 7th Jan 2009, 10:20 -
How Can You Tell which one(s) are the directors commentary
By jah711 in forum Blu-ray RippingReplies: 1Last Post: 25th Aug 2008, 02:00
