  1. Hi ChrissyBoy,
    I am having trouble with the HD .MTS video recorded by my Panasonic HD Camcorder. I have tried changing the file extension to .TS, AVSWrap, etc.
    Here is my error:
    Version: SVCD2DVD 2.5
    Build: 2.5.5030.0
    Type: System.AccessViolationException
    Source: SVCD2DVD
    Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
    and my log:
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Hi Dwight,
    Can you confirm with MediaInfo there are 2 audio streams or just 1? (in fact can you post the details?)
    Cheers.
  3. Hi Chris,
    One audio stream.
    Dwight
    - Herm Albright
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Mmm - it is mistaking the Text stream as an audio stream...... Is this happening for all MTS files from the camcorder? If so - can you upload me a small sample which exhibts the problem (I can PM you FTP details etc).
  5. It appears to be the same on all files. I have some small clips, PM the FTP info.
    Dwight
    - Herm Albright
