Hello, and thank you in advance for any help. Also, if I've posted this in the wrong forum then I apologize for my mistake and please move it as you see fit. I've been using MeGUI and MkvMergeGUI in tandem to first convert the superfluous (for my needs) audio and-or video of various movie containers, then remux the new combination of files. I've noticed when I either convert the video or it originated from a non-mkv container, that the resultant .mkv file's title when opened in my player is, by default, the "Output filename" from MMG. However, when the video I remux is not converted and came originally from an .mkv container and has text in the "File/segment title" box in the "Global" tab, that this text, by default, becomes the newly muxed .mkv's displayed title when opened in my player. My question: is there any way to either set the default for "File/segment title" in the "Global" tab to blank or to automatically load the "Output filename" into the box? Or, if neither of those options is possible, is there any way to edit the "File/segment title" text without having to remux? Again, thanks for your time.
Results 1 to 1 of 1
VirtualDub *.MTS "Unable to set filename on media detector:hr=80040200"
By Innomen in forum Video ConversionReplies: 15Last Post: 27th Aug 2012, 09:24 -
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 19:35 -
Set/Fix QuickTime "atoms"/"flags"?
By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 14:07 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40 -
"Cannot append segment...", "Mismatch detected..."
By Ygramul in forum Newbie / General discussionsReplies: 2Last Post: 14th Jun 2007, 12:32
