My sister-in-law gave me her old 37" 720 HD TV. It does not have a qam tuner, so I can't view the free / clear qam channels that TimeWarnerCable broadcasts in their $10/month "Broadcast Cable" package.
If I wanted to purchase an external qam tuner, is there anything better than this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815260027&cm_re=qam_tuner_box-_-...-027-_-Product
Dig
There are few stand alone ATSC/QAM tuners available that are 720p/1080i capable. Here is the full list (including discontinued) http://www.avsforum.com/avs-vb/showthread.php?t=179095
One other to compare is this one http://www.channelmasterstore.com/HD_Antenna_Tuner_CM_7001_p/cm-7001.htm
I have no experience with any of the current models.
That AVS forum is probably the best place to ask
There is a wide choice of computer QAM tuners.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
if you buy a used one from ebay .be sure they offer a 7 day return .many of the used ones specially Samsung suffer from bad caps (mine Samsung DTB-H260F replaced the caps twice)
I've got one of those K-Worlds (actually the VGA/Component version) and it works pretty well. I occasionally have to re-boot it and for some reason it drops channels once in a while. Plug your zip code in here: http://www.silicondust.com/support/channels/ and you should get a list of what to expect. Also the remote seems to have been designed by Space Aliens, as there are no words (just obscure symbols) on it.
QAM, QAM tuner
By Baldrick in forum GlossaryReplies: 5Last Post: 12th May 2009, 12:17 -
Hauppage or other QAM support TV tuner cards and EQAM
By bithead9 in forum Media Center PC / MediaCentersReplies: 1Last Post: 23rd Apr 2009, 04:22 -
QAM tv tuner
By maryhigginsrice in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2008, 08:58 -
Can you explain to me what a HDTV with QAM tuner is?
By davidsama in forum DVB / IPTVReplies: 1Last Post: 30th Sep 2007, 16:17 -
Another reason to make sure your next TV or DVD recorder has a QAM tuner...
By zzyzzx in forum Off topicReplies: 2Last Post: 7th Jun 2007, 15:40
