Hello,
Recently I bought Sony 32EX520 LED TV but I am not able to play .MKV file via USB drive while other video format i.e. .AVI and MP4 are playing without any issue.
Pls suggest me some option to convert MKV to AVI or MP4.
I have already tried lots of video file converter but they all takes huge time in conversion and file size becomes hugs in aprox 2GB, 4GB etc.
AVIDEMUX: its good in some case but in many case there is huge time lag in visual and audio after conversion.
I know your guys are genus here as far as video help is concern. Pls help me too.
PREM SONI
Premsoni4u@gmail.com
XmediaRecode. Load the mkv. Set the output to MP4. Set the Video and Audio modes to copy (tick box at the bottom of the Video config tab, selection in the drop down for audio), add the job to the queue, then process. Should take only a couple of minutes, should remain around the same size, and won't re-encode. What you will lose is embedded subs, but you can grab these from the mkv file with mkvextract and put them with your mp4 file on the USB drive.
Read my blog here.
Hi,
Thanks for reply. I tried XmediaRecode but Video file more than 1 GB, after converting in MP4 format, are not playing on my Sony TV on USB drive.
Pls suggest some other way to do so.
How to convert any video to AVI or MP4 or MKV with burned in subtitles
By Baldrick in forum User guidesReplies: 42Last Post: 19th Nov 2015, 05:41 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
Why video and audio out of sync while playing .mp4 and .mkv files?
By Bonie81 in forum Software PlayingReplies: 0Last Post: 6th Apr 2010, 18:03 -
What the best format to convert to, AVI(Xvid), MP4 or MKV
By adamf154 in forum Video ConversionReplies: 2Last Post: 1st Mar 2010, 16:48
