i bought that program for my windows comp a few years ago, and now that i'm a mac, i miss using that program. it would take just about any video format i would have and convert it to any other format i chose. as well as crop video in anyway i wanted unlike imovie on the mac. is there a mac equivalent to tmpgenc 3.0 xpress ?
i have macx video converter pro but even that has a big problem converting wmv's. it crashes most of the time. but it only converts, it doesnt allow me to crop OR combine several clips into one like tmpgenc allowed me. any help guys?
I never use it but ffmpeg works under Mac and it might be able to do the job for you. I can't help you with it as, again, I never use it.
Even the most hardcore Mac fanboys I know bought VMware Fusion and use it to run programs under a Windows VM on their Macs. You could always go that route. -
Without the Flip4Mac -paid- plugin installed, you'll get a watermark in the converted video. What I do is use XP (or Windows 7) in Parallels, open the WMV in Movie Maker, export as DV-AVI and drop that file into Handbrake (back on the Mac side). The settings you use there are dependent on the device(s) on which you want to play that video.
Once you have the file(s) back om the Mac side, you want to have the Perian plugin installed. To combine multiple videos into one, use MPEG Streamclip. That all will also do the conversion to H264/MP4 for Mac-friendliness. -
well as much as i appreciate the info, it doesnt seem like there is just a mac version of that program i love...seems i need so many different apps to just get it to do one thing that windows is great for...thanks anyway.
"so many"? One on Windows and one on OSX.
If you -buy- the Flip3Mac WMV plugin (instead of using the free version), you may do the entire thing with MPEG Streamclip.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
