I recently captured several (50+) DV tapes into AVI Type 1 files using WinDV. While capturing, I had WinDV create a new file each time the time code was disrupted, indicating the camera was paused. This gave me several hundred clip files, named by time code, making it very easy to identify groups of clips that were taken on a particular day or time of day...
Using TMPGnc Express 4.0, I loaded all of the clips for a particular outing and then applied a Fade In and Fade Out filter to both the video and audio for each clip. (TMPGnc Express supports Group Filtering.) I then encoded all the clips into a single video file.
I'm very happy with the results as I now have nice transitions between scenes and would like to do this to all of the video I've captured. The problem is, it is very tediously manual and time consuming to do this with TE4, especially since I haven't figured out a way to avoid re-encoding the final single stream to file.
I'd like to find a way to batch process a group of files within a folder into a single file, but after a lot of searching here and on the internet, really haven't found what I'm looking for. I started to look at avisynth but the learning curve seems very high...
Has anyone out there done something similar or has some ideas for me?
Thanks in advance!
Adding Fade In / Out
By willmington in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 08:25 -
Can I do a simple fade in/out on clips pulled from BD without re-encoding?
By Dan Miller in forum EditingReplies: 4Last Post: 7th Jun 2010, 01:31 -
VirtualDub: Fade between clips effect
By David_UK in forum EditingReplies: 5Last Post: 14th Apr 2009, 15:25 -
Separating 2 Clips joint by fade in effect?
By InSaNiTy in forum EditingReplies: 0Last Post: 3rd Aug 2007, 15:19 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 17:02
