Hi!
I would like to know if it is possible to use avermedia capture hd pci card with firewire/dv output of a sony videocam.
I am currently cupturing through s-video because the sony outputs rgb and the avermedia recieves component...
I would like however to use the DV out because it is supposed to be the highest quality.
My computer has firewire inputs and it is possible to capture through it with windows movie maker.
However, i would like to capture through the avermedia software and use its hardware h264 compression.
Thx for the help.
Zach
Thx for the reply,
However, i need a simplified solution as i am capturing realtime surgery.
I do not want to capture with one software and then edit with another. I would like to use the avermedia card to capture , show realtime fullscreen preview and encode to h264 via FIREWIRE if possible.
Any other suggestions ? -
no. it's not a firewire card if it's the one i'm thinking of. you could get a new cam and record HD over hdmi if you wanted higher quality.
AverMedia C027 HD Capture Low Audio
By XmnwildX12 in forum Capturing and VCRReplies: 3Last Post: 29th Jun 2011, 21:03 -
Help watching tv on Avermedia HD DVR capture card
By mason dixon in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2011, 12:00 -
AVerMedia AVerTV Capture HD with GraphStudio problem
By feeltherock in forum Video Streaming DownloadingReplies: 0Last Post: 18th Feb 2010, 13:47 -
Hauppague WinTV-HVR-1600 vs Avermedia capture card with SAA7130 chip
By johnnyquid in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2008, 19:29 -
4 port capture card - avermedia lx5004 - not working correctly
By 4dplane in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2007, 21:39
