Hi there,
For a whole while I have been wondering about the following: when I create a music podcast, I sometimes make a video with the album covers and some text ... in a 450x450 pixel format - since the covers are all square, why not doing the same thing for the video, right?
Anyway, when exporting from for example Sony Vegas, and selecting a codec that is able to compress pretty good (a podcast takes 32GB in the uncompressed codec) I get errors. On any station I try to do it. Only the uncompressed codec is able to export 450x450, but for example Cineform Neoscene (that I can partly understand, as it is developed for DSLR use) or Lagarith (which I don't get at all) are not able to compress to this format? Why is that? Is there a reason I don't know of?
Greets,
Frank
Results 1 to 11 of 11
What errors do you get ?
Some formats work better in multiples of 16 (mod 16) depending on the colorspace, try 432x432 for instance, or 448x448
Lagarith in RGB mode should be able to render at any resolution, but lagarith isn't suitable for a streaming podcast. You would probably want to use a flash format, with h264/aac -
It's probably not the aspect ratio itself that is giving problems.
Most codecs require frame dimensions that are a multiple of 4 (and often require multiples of 8 or 16).
450 does not meet that requirement.
Ah - pdr beat me to it. -
Most of the standard lossy codecs, the ones in common use, work their magic by using the DCT (Discreet Cosine Transform), which partitions up your frames into blocks of pixels and processes each block. Those blocks are usually 16 pixels wide (can sometimes be 8 or 4 or 2). Some of them are constrained even further by expecting ONLY certain sizes and dimensions.
Your video is only evenly divisible by 2, so those codecs that expect Mod16 sizes will cough up your video - sometimes stretching it, sometimes (if they're programmed well) adding black padding), sometimes not working with it at all.
Just because your still/menu/thumbnail is one dimension does NOT mean you should make your video that way. There are standards out there; if you want your stuff to be well recieved by many, stick to one of those standards.
ScottLast edited by Cornucopia; 7th Jul 2011 at 10:40. Reason: I wrote too much and was also beaten...
Nice replies ... I heard about those division of 16, but never knew what exactly it meant. I'll try it right away! Thanks a lot!
Interesting, what version of lagarith are you using jagabo ? I'm using the latest and it doesn't list any restrictions
And a quick test shows 450x450 RGB lagarith works fine, decodes fine
Other formats e.g. ut video codec have mod2 restriction on YUY2/YV12, but none on RGBLast edited by poisondeathray; 7th Jul 2011 at 19:22.
something doesn't make sense (aspect ratio question)
By njitgrad in forum Newbie / General discussionsReplies: 6Last Post: 21st Nov 2010, 17:29 -
Video aspect ratio conversion
By cd090580 in forum Video ConversionReplies: 15Last Post: 22nd Sep 2008, 06:08 -
Will my video programs, codecs, etc, still work with Windows X64?
By HartsVideo in forum Software PlayingReplies: 15Last Post: 5th Sep 2008, 13:09 -
how to change aspect ratio of video?
By curt1sw in forum EditingReplies: 2Last Post: 25th Nov 2007, 07:42 -
how to change the aspect ratio of a video?
By curt1sw in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2007, 08:46
