  1. How to remove nasty animated logo?
    Here : Sample
  2. cover it with black?
  3. Those are a lot of fun, aren't they. I've done it using AviSynth's InpaintFunc:
    http://avisynth.org/mediawiki/InpaintFunc
    If there's a way to animate the logo remover itself I don't know about it and would like to learn. For yours, I'd break it into 3 pieces, the move half way down, sitting in the middle, and then the rest of the way down. Here's an example of where a logo sits in the upper left for the whole song, but a couple of times it starts at the bottom and then moves back to its position in the top left. I broke the removal into 2 parts, lower left and top left, and you can see the results between about 1:35 and 1:40 in the video:
    http://www.youtube.com/watch?v=WIFbQ0HtVSs
    Edit: Reading jagabo's reply: Yes, if it's only on that black background, much easier would be to just cover it with black. I was assuming in a video it'll show up over some 'real' video underneath.
  4. i knew it....
    you two guys jagabo and manono gonna definitely come-up with some nasty ideas....
    @ manono
    i thought you might be busy in Hollywood for new shoot of Matrix - Rebuilt coz The director Hankie has already already re-loaded the matrix in HcEnc 026beta last release. Nobody even knows when you are hiding behind the standard ones.
    AVISynth is real FuN for pros and for beginners as well!
    Have FuN!!!
    See ya around!
  5. @ manono
    Director "Hankie" was cast-screening for co-star in Matrix-Rebuilt, here is a SAMPLE.
    Hope you will like the co-star, and approve as a co-star.
    But, the problem is nasty animated logo....Dropping in like a villain from no where.
    So, start playing only I mean ONLY with nasty logo, as there is an another attraction too!
    Probably you guys wanna remove more than just a logo!!!!!
    Have FuN!!!
    As a friend, take it light n easy and laugh. DuNNo try to kick me hard, Matrix hero.
