I have a chipped panasonic DVD player with macrovision removed/region free. It will allow me to record to VHS original DVDs and some d/loaded VCDs.
I have a problem in putting onto VHS some newer VCDs. They copy ok but have what can be best described as flickering horizontal lines across the screen.
Any ideas what causes this and if possible any solutions.
Maxiesmudge, I assume that you are talking about VCD's that you Purchased, If the screen is jumbled up, and not any picture is distinguishable, try watching it without recording, my bet is that you have
a clear image then, right? More then likely, its a Copyright protection.
Now, i am new to VCD's, and i am even suprised that there are chips... anyway, i just wanted to make a note, and tell you that its a copyright protection, and i don't know if there is anyway to disable this, good luck, and hope you get it fixed. (note, this also happens when you try to record from a dvd that you have purchased) -
The problem is with VCDs I have downloaded and converted. I believe the prob is to do with PAL/PAL60?NTSC. I can change the output to NTSC but still the problem persists.
Original dvds can be put onto video perfectly. The chip removes macrovision/makes the dvd region free/allows mp3s to be played.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 01:56 -
VHS Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 08:58 -
mystery VHS problem...
By johnnyblast in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2008, 13:08 -
VHS -> DV -> Camcorder problem
By Kirkman in forum MacReplies: 2Last Post: 14th Feb 2008, 19:47
