    Dec 2010
    quebec
    this is a recording back in 92 it's the audio from a video file that came from a cam really close to the stage so the input is distorted
    i wonder if with a good notch filter if i could isolate the annoying frequencies and make it a little bit softer and maybe limit the bass to make it more listenable
    we played this song a few months after the album came out
    you can try this out and tell me what you did and i'll try to emulate the results
    i made a flac file from the original wave (Level=0)
    lots of people here have really good results with less that good video files
    hoping it can be done with audio too !!
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Painful clipped recording dude. Oh my ears (oww) and you may have ruined my speakers.
    http://www.kiva.org/about
    Dec 2010
    quebec
    turn it down.. if i could only turn down those annoying frequencies
    i'm searching now for somekind of frequency analyzer so i can pin point what could be turn down
    Dec 2010
    quebec
    just found this little app http://downloadsquad.switched.com/2009/02/09/free-audio-editor-provides-advanced-audio...s-for-windows/ but i'm gonna play with it more tomorrow
  5. Mod Neophyte redwudz's Avatar
    USA
    I would try the freeware audio editor Audacity instead. It's liklely a lot more advanced than that application. But if the audio is badly clipped, there may not be anything you can do. This is with noise removal and a bit of bass boost. The voice part is severly distorted, probably not much can be done there. And since this is an audio question, moving to our audio forum.
    Dec 2010
    quebec
    you boosted the bass ?? ...ok i'll tried audacity (i hink it's kinda overrated)
    you managed to give the vocals a little boost it's flangy i'll try again
    i taught this was closer to restoration ( filtering and enhancing)
