I shot my fireworks display with my Nikon P100 camera. I've shot many videos with this camera before without any issue. However this one time during the display my battery went dead so I quickly swapped batteries and continued filming the show. Well the first file plays fine however the second file (on new battery) starts fine but the audio progressively gets more and more out of sync - in upwards of 3 to 4 seconds in a 4min video.
Now I've fuddled with video a long time, lurked here often, but first time posting. I've had this issue before and I've always been able to fix it one way or another. However this is the first time I have not - also the first time the source video was QT / MOV.
I've tried playing the original file on different machines and numerous players (vlc, mpc, wmp, divx player, and even in QT) they all experience the audio sync issue.
I've tried re-encoding the file to raw uncompressed audio / video AVI then remuxing it (this has always worked in the past as a last resort) but not this time.
So my real question here is - is there any one thing that'll fix this issue or am I going to have to manually shift the audio various amounts throughout the whole video!?
What did you try reconvert it with ? Try mpeg streamclip and quicktime pro.
But I'm pretty sure it wont help so you have to manually resync. -
I figured QTP would be my ultimate last option - I didn't want to pay for it if it wasn't going to resolve the issue. I typically use TMPGEnc 4.0 But I've also tried the DivxPro converter, avidemux and virtualdub.
are there any "glitches" in the recording ? If there are , you probably have to manually resync in an editor
what does mediainfo say about the lengths of audio & video (view=>text) ? if there are no glitches and it's just a mismatch, you might be able to fix it by stretching/shrinking either the audio or video to match. -
mpeg streamclip was very quick but same issue - still out of sync in all the same places
mediainfo
General
Complete name : E:\SHARE\_PICS\2011.fireworks\DSCN1369.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 481 MiB
Duration : 4mn 39s
Overall bit rate : 14.5 Mbps
Encoded date : UTC 2011-07-02 21:01:56
Tagged date : UTC 2011-07-02 21:01:56
NCDT : NCTG
Video
Format : AVC
Format profile : Baseline@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
Duration : 4mn 39s
Bit rate : 14.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.230
Stream size : 476 MiB (99%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 4mn 39s
Bit rate mode : Variable
Bit rate : 128 Kbps
Maximum bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 4.24 MiB (1%)
Language : English
Material_Duration : 284459
Material_StreamSize : 4528558
Looks like the duration is the same between audio and video streams. I wonder if QTP can fix this or if I should just manually fix it. -
alrighty - i figured as much well thanks for trying everyone you're input is much appreciated
edit - I used mpeg streamclip to export the orig file to an avi. I then popped the avi into avidemux to set the audio shifts and just save portions of the video (not re-encoding anything) since I had to chunk it up about 6 times with various shifts starting at -1000ms and ending with -4800ms!
so now my question is what is the most efficient way to piece these shifted files together so it won't screw up the audio again in the process?
edit 2 - nvm I guess avidemux can do this I'm looking up how now
thx again everyone - once I get this pieced together I'll post it for your viewing enjoymentLast edited by MALIGNITY; 7th Jul 2011 at 10:49. Reason: rtfm
Here is the finished product. Once I got the audio fixed I appended all the parts into avidemux (superb utility btw) then re-encoded to try and make the filesize smaller. Used 800x600 1000bit rate xvid and got it down to 80mb then threw it up on Youtube for your enjoyment.
Thanks again for all the help guys.
http://www.youtube.com/watch?v=7Zi5gMwdZgo
Mov audio/video sync problem
By adabo in forum EditingReplies: 7Last Post: 28th Jun 2018, 12:09 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
.Mov Videos Out of Sync
By bguguen in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2009, 19:09 -
Out-of-sync MOV File
By xeroid in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2008, 15:41 -
Seeking help on "bleeping-out" bad words
By dough in forum Newbie / General discussionsReplies: 20Last Post: 26th Sep 2007, 15:50
