Results 1 to 11 of 11
  1. Hi
    when encoding my avi with AVStoDVD, it adds black borders to the left and to the right. I guess it's because some TVs hide these parts of the screen... but I think these borders are too large. Is it possible to reduce them?
    Another question: is it possible to stream copy the audio? I have an AC3 source and I would like to avoid reencoding it..
    thanks
  2. Originally Posted by mathmax View Post
    Of course Go to 'Edit Title'/'AviSynth', toggle off 'Auto AviSynth Script' and play with 'Vertical Resize'.
    If the AC3 source is DVD compliant, it is already reteined. Check if 'Edit Title'/'Audio'/'Keep DVD compliant Audio' is toggled on.
    Bye
    MrC
    AVStoDVD Homepage
  3. Thank you
    Can I remove completely the avisynth script? Cause audiodub() will reencode my audio..
    Also, is it possible to shift the audio cause it doesn't start at the same time as the video.
  4. Originally Posted by mathmax View Post
    As I told you before, if in 'Edit Title'/'Audio', the option 'Keep DVD compliant audio' is on, then audio will be retained. In that case, video will be encoded thru AviSynth frameserving, audio will be demuxed by FFmpeg.
    Yes, it is. Same location as before: 'Edit Title'/'AviSynth'/'Delay Audio'.
    Bye
    MrC
    AVStoDVD Homepage
  5. Originally Posted by _MrC_ View Post
    Bye
    If I edit the avisynth script, then I can't check the option "delay the audio"
    Strange that this option is in the "avisynth" tab, since avisynth will not be used to process the audio as I checked 'Keep DVD compliant audio' to direct stream copy the AC3
  6. on me....
    Of course if audio is retained, 'Delay Audio' will not work. You have to re-encode audio to apply the delay. Or, alternatively, you can edit the BatchMux command parameters ('Advanced Project Settings'/'Edit encoder commmand params at runtime' and, just before authoring step, add:
    -a1delay xxx
    where xxx is the delay in ms (min -300, max +300)
    Bye
    MrC
    AVStoDVD Homepage
  7. I would like to delay it of -2903ms.. I'm under minimum value
    Any alternative solution? For example? Is there a software cut .ac3 without reencoding?
  8. Originally Posted by mathmax View Post
    delaycut
  9. Originally Posted by poisondeathray View Post
    delaycut
    Thank you
    I also thought of using dgindex to extract again the audio.. but dgindex is not accurate to cut a video. Could you advise me a demuxer that allows to cut at an exact frame?
  10. frame accurate cut for mpeg2 video = videoredo
