I'm converting my HD DVD's to BluRay (movie only on DVD9). I've successfully ripped and converted and HDDVD (the Matrix) to a bluray file structure on my HDD and I can play this just fine. I converted this file structure to a bluray ISO which also mounts and plays fine.
But when I use BD Rebuilder to resize the ISO to fit on DVD9, the resulting file structure has a vertical displacement of color versus brightness. Hard to describe. But the falling symbols in the opening of the Matrix, the lead letter of each falling column is white and the trailing letters are green. A small strip at the bottom of the screen is in black & white.
Any clues as to what's causing my issue?
Program flow:
AnyDVD on
EVOdemux(v0.63) to rip to HDD (movie only)
vc1conv to convert .mpv video to .vc1
eac3to to convert .mpa audio to .ac3
tsMuxer (v1.10.6) to convert to .ts
tsRemuxer (v0.0.21.2) to convert .ts to a bluray structure
Results 1 to 1 of 1
After update color issue?
By NEO Ness in forum RestorationReplies: 6Last Post: 22nd Dec 2011, 19:37 -
Audio Issue with BD-Rebuilder BD-RBV03804
By alejandroricardo in forum Authoring (Blu-ray)Replies: 5Last Post: 19th Jul 2011, 14:49 -
Bd Rebuilder Failing on Encoding
By Westie69 in forum Blu-ray RippingReplies: 4Last Post: 31st Mar 2011, 02:52 -
BD Rebuilder failure to extract audio issue
By fnord333 in forum Blu-ray RippingReplies: 8Last Post: 26th Mar 2011, 13:37 -
DVD-rebuilder issue: DVD9 to DVD5 not working
By Hurre in forum DVD RippingReplies: 13Last Post: 1st Apr 2008, 18:46
