Hello, Just joined and I am hoping you experts can help.
I have a denon dvd 1000 and want to make it region free does anyone know how to do this.
It's a great played and works fine I jst want to play some dvd form elsewhere and need region free.
No harm in asking and maybe you'll be one of the rare lucky ones who gets a positive response from a request like this. However most DVD players sold in North America cannot be unlocked. I did a quick check and no unlock codes have been reported for your player so the odds are that you will not be one of the lucky ones. But sometimes these requests do get codes months later so you might want to check back at some future date if a code doesn't show up in the next few days. I'm not sure but if there's an option under your account to notify you if threads you post to get updated, you might want to turn that on for this thread just in case.
This works for me, but you have to change to the region that you require at each point after you have loaded the region disc you want to watch
Load disc
Using remote
Place unit in standby
For region 1
Press 1 - select - 1
Then press standby to turn unit back on
The unit will load looking for region 1 disc and play it
If u try to play another region disc the unit display will show " no play"
Follow same method above to return to region 2 etc each time using the region number that you require in the string
Denon DBP-1611UD multi-region DVD player giving puzzling message onscreen
By outfoxed in forum DVD & Blu-ray PlayersReplies: 7Last Post: 20th Aug 2011, 04:39 -
Sony BDV-IT 1000 Make region free
By nicho1001 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Jan 2010, 02:33 -
Region free code for Blue Ray pleers Denon DVD-3800BDCI
By zet in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Oct 2009, 07:47 -
denon 102 region free hack wanted
By CODEWERKX in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Jan 2008, 13:21 -
region-free code/firmware for DENON 1740
By abraxox in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Nov 2007, 16:05
