Hey all,
A client has sent me some ProRes files. I need to be able to pass these through HandBrake 0.9.4 CLI for batch encoding to MP4. Usually they send me DVDs or DVD images and so this is not a problem, but now...
The ProRes files have a much higher bitrate than DVD spec so it would be nice to preserve that, but I can't think of a very good way to do that with an intermediary format. Currently trying test batches by using QuickTime to export the ProRes stuff to DV / DVCPRO and feeding that to HandBrake. Another option would be exporting to uncompressed AVI, but that will probably result in huge files which will a) take forever to process, and b) bottleneck the whole thing on the transfer speed to the external hard drive storing the video files.
I'm sure somebody out there is more clever than I am. What's the optimal way you would make ProRes (422) into a format HandBrake can read? Any help greatly appreciated.
Results 1 to 1 of 1
Convert 1080P to 720P using Handbrake !
By augustya in forum Video ConversionReplies: 24Last Post: 11th Oct 2011, 04:53 -
Most practical method to convert from ProRes to AVCHD
By mikeveli20 in forum MacReplies: 0Last Post: 12th Mar 2011, 15:21 -
Using Handbrake to convert files for WDTV
By Tassie in forum Video ConversionReplies: 5Last Post: 3rd Apr 2010, 19:02 -
HandBrake + WMV/H.264 input = no joy?
By x2x3x2 in forum Video ConversionReplies: 4Last Post: 10th Jul 2009, 00:29 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59
