How is the capture image quality compard to MMC 7.5? Is it worth the upgrade?
Results 31 to 39 of 39
I just upgraded to MMC 7.6. It changed something about my capture driver, because now I can't capture avi at anything over 240 vertical resolution. ATI's fix for interlace lines, perhaps?
Am I the only one that's experiencing this problem?
Overall it seems to be more stable than 7.1. -
I also upgraded to 7.6 from 7.2 and I cannot capture anything above 240 vertical either. I also cannot capture MPEG files. AVI is fine.
Anyone know of a fix? -
I had to install 7.1 from scratch. Then set custom 480x480 avi huffy profile. Then install 7.6 on top. THe profile carried over, and now can capture 480x480 in 7.6.
Hint: in order to install 480x480 avi profile, you have to start with 640x480 avi, save , go into regedit , and manually chance the 640 to 480.
maybe i'll write a little primer, or a registry import file. -
Where in the REG do you find the correct default to change? I current use the standard MPEG but the AVI is much better.
Bud -
when I get home, I can give specifics. This registry hack does not work in 7.6, which is why I had to start with 7.1, because I had been doing it with it before.
I do know it's under hkey_current _user, not hkey_local_machine. Go to software, ati, and you'll find an avi section. just dig down till you see your 640 and 480 mentioned. Change the 640 to 480. If I remember right it might be in 2 places in the same area of the registry. -
i own All in Wonder Radeon
just load MMC 7.6
http://www.ati.com/support/driver.html
link to chose your OS and appropriate software
for your Ati product
i just discover the new release on march 30 !
i fall in love with it :P
------better vcr options (incredible choice )
------link and explanation to window media encoder
------better skin
------quick lunch with browser file playing 8)
------working instantly ! ( follow all site instruction)
link to window media encoder
http://www.microsoft.com/windows/windowsmedia/wm7/encoder.asp
also load and try window media encoding program
it's compression is unbelivable !
(now i can share any video with resonable size
thanks to ATi -
For those with the Radeon:
What driver r u using with 7.6?
My TV on Demand function quality sucks! Slightly jerky picture and after capturing for over 90 minutes or so it's hard to fast forward. -
I found MMC 7.6 on the ATI website with no problems. You can download it from ATI at: http://download.ati.com/drivers/MMC-7-6-noDVD.exe
MarkS
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 13:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
