A MSI PM8M3-V motherboard with 3.2Ghz P4 processor shows high, erratic cpu temp. I tried removing old compound from heatsink and cpu and replacing with arctic silver which didn't reduce cpu temperature shown in bios. However, can temperature shown in bios be wrong? I installed the Motherboard Monitor program that shows cpu temp 30 C and case temp 29 C. Temperature shown in bios is 68 C for cpu and 30 C for case. Also bios cpu temp fluctuates rapidly between temps from 66 C to 72 C while the Motherboard Monitor temp is very stable and changes very slowly as cpu runs various processes, and heatsink feels just slightly warm to the touch. Other systems I've built also have very stable cpu temp shown in bios. Could it be the bios cpu temp is wrong for this motherboard or whether there's a way to determine true cpu temp for this board?
	That seems a bit odd as both the BIOS and the PC software would be using the same temperature processing IC and reading the same sensor. The sensor for newer CPUs are part of the CPU. Then a small integrated circuit on the MB does the reading.
 The software program should also be using the same data from the temp IC. You may have a bad temperature sensor in the CPU, it happens. If you can hold your finger at the base of the CPU heatsink comfortably, it's not at 72C (162F).
 I would check to see if you have the correct BIOS for your MB. It's possible that that could be the problem.
	bios temps are not related to windows temps. while in the bios the cpu is running 100%. while sitting in windows near 0%. --
	I just bought the motherboard, and it has the bios it shipped with which I'd think would mean it couldn't have the wrong bios. Another thing that stands out to me is the large difference in cpu and case temp shown in bios because temps I've seen in many other systems have never been more than about 7 C difference between cpu and case and usually even less than 7 C difference. This makes me think it's likely a bios bug especially considering it feels only slightly warm when I touch my finger to the heatsink.
  CPU temp "alert"By Edgarke16 in forum ComputerReplies: 2Last Post: 20th Feb 2011, 18:44
  CPU Temp.By HotDamn! in forum ComputerReplies: 33Last Post: 8th Mar 2010, 14:21
  BIOS Question regarding new CPUBy ron spencer in forum ComputerReplies: 3Last Post: 4th Jun 2009, 10:23
  Standalone CPU Temp Monitoring AppBy Soopafresh in forum ComputerReplies: 8Last Post: 17th Mar 2008, 02:51
  CPU TempBy Willy5157 in forum ComputerReplies: 4Last Post: 9th Feb 2008, 21:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
