Ok, I know you can use AVIdemux, but when I try it, the audio is out of sync. Is there a program that edits an MKV file as well as all the tracks including subtitles?
Anime on Laserdisc is teh awesome
Not really, because MKV is not built for editing, and no serious editing tool will work with it. Try a couple of different version of AVI Demux and see if one works better than the others. Otherwise look at converting the mkv to something like m2ts (should be do-able without re-encoding) and see if you can work with that format instead. Of course the next issue you will face is that very few editors will work with H264 without re-encoding it.
Read my blog here.
I use Virtualdub. There are two options. You will need the MKV plugin from fcchandler, aac plugin from fcchandler, x264vfw and MKVtoolnix (mkvmerge).
Option one: Make your cuts > choose Video > Compression > x264vfw > Smart Render > Audio > Direct Stream Copy > Save Avi > open AVI with MKVmerge and mux to MKV.
Option two: Open mkv in Virtualdub > move to first cut and note time (example: 0:00:13.019), move to last cut and note time (example:0:51:55.546). Open mkv in MKVmerge and choose Global > click Enable splitting > tick After time codes > enter 00:00:13.019,00:51:55.546 > under maximum number of files enter 3 > click Start muxing. Three files will be created. The intro, the movie and the credits.
a problem opening MKV or MP4 files
By gis4ever in forum Video ConversionReplies: 10Last Post: 7th Jul 2010, 13:39 -
VirtualDubMod crashed on me while opening an MKV file
By The Monarch in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2009, 07:57 -
Using Xvid4PSP convert mkv to mp4 ending up with no video, only audio
By divmehz in forum Video ConversionReplies: 0Last Post: 7th Dec 2008, 17:57 -
Cutting VOB File without any quality loss? (ending credits)
By willhenderson in forum Newbie / General discussionsReplies: 10Last Post: 15th Oct 2008, 23:45 -
Remove intro and Credits from a MKV File
By andrema71 in forum EditingReplies: 1Last Post: 15th Jun 2008, 11:08
