Results 1 to 11 of 11
    gold coast, australia
    i have used orbit for a few years now since it being recommended in this forum.
    however since i started using google chrome it no longer works...either in chrome or IE.
    I have re installed it making sure chome settings were ticked but it still doesnt work,
    correct me if im wrong, but whenever i opened a video steam a download button icon appeared ...but that doesnt happen anymore.
    what am i doing wrong?
  2. Banned
    Freedonia
    I used to use orbit too, but I stopped because it wasn't being updated and it stopped working on a lot of sites. You might try StreamTransport which is free and works better but there are still some things it can't get.
    Jan 2003
    India
    Use Latest Firefox with Video Download Helper Extension
    orbit worked great till i changed from IE to chrome, now it works on neither
    worked a treat once i worked out how to use it!@
    cheers
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    StreamTransport hasn't been updated for over a year, it doesn't work on many sites, like Hulu, despite that being its main "feature" according to its website.
    Still works for some streams though, so worth a try.
    how do i find all the orbit files on my comp? i have uninstalled and googled it....have done everything i can but all new downloads go to a page saying orbit is downloading it ...but there is no orbit on my comp
    their FAQ page said got to documents and delete the orbitdownloader folder but there is no folder there
    its very frustrating means i cant download anything unless its a torrent....tried updating copytransmanger just then and cannot ggrrrrrr annoying
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    REinstall Orbit.
    Then you should be able to UNinstall it properly.
    Hopefully this includes the browser plugins that are giving you problems.
    already done this
    and re uninstalled it
    tried downloading copytrans manager and other free downloads and it goes to the same page
    what an absolute pain in the butt
    Mar 2008
    According to http://www.orbitdownloader.com/how-to-uninstall.htm
    you delete the orbitdownloader folder from c:\program files\
    and the orbit folder from c:\documents and settings\*your_user_name*\application data\ << this is the XP folder name,
    probably different in Vista or Win 7
  11. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    They've got a forum, http://forum.orbitdownloader.com/
    Ask there.
    Be descriptive and not accusatory if you want them to help.
