Page 2 of 2
FirstFirst 1 2
Results 31 to 37 of 37
    Jul 2011
    Isfahan
    thanks
    i know i should change the decoder part.
    but how exactly?
    i use megui.
    and what about d2v .
    my source is some kind of x264 video in *.mkv container .
  2. Now I'm confused,.. you should not have to change the decoder if you use megui, since it should select the most suited decoder for you,....
    Jul 2011
    Isfahan
    so you mean i should delete the decoder part from script and use it with megui?
  4. You should modify the avisynth skript megui uses:
    switch the stuff behind a1=.. with whatever megui uses in it's avisynth script and use of the script posted here,...
    Jul 2011
    Isfahan
    thanks
    i'm still a newbie tries to learn.
    so excuse me.
    i will try your guide and will ask a lot of questions near future.
  6. As Avisynth newbie you might want to read: http://avisynth.org/mediawiki/Main_Page#New_to_AviSynth_-_start_here to get a basic understandig of how to skripts function.
    If you have problems with a specific script post it.
    Cu Selur
    Jul 2011
    Isfahan
    dank
