Ok so i got the AVT-8710 from BH
Unfortunatly i am still dropping frames occasionally but it at least is giving me a constant signal.
ANyway i have just tried some tapes from 1989 and results are not good.
The AVT-8710 TBC is stuggling, i think.
I am getting on capture freezing or ghosting....
Is this the TBC not handling the tape?
Would the Datavideo TBC-1000 do any better?
It is really annoying not being able to capture these 8mm tapes..
It seems to be capturing but u can see on the preview window that its stopped and when i play the avi file it stutters and ghosts,,
any ideas?
	Upload sample.
 Also read this: Is my new AVT-8710 DOA? Screen Shots...
 You may want to contribute your chipset information to that thread.Want my help? Ask here! (not via PM!)
	So it does not do this all the time but enough that it is way annoying and unwatchable!
 I personally thought it was the TBC due to the fact that before i used it the tape was uncapturable and now it is.,.. sortof
 and second due to some reviews saying:
 "A semi-con is that it doesn't just fix the bad part of the picture like more expensive TBCs, it freezes the entire frame, so when things get bad with your picture it will 'freeze' on the last good frame until it finds the next good one (like half a second later, usually), and your recording will have a 'ghost' image quality to it."
 I am now looking and asking around if a more expencive/prosumer TBC will improve my results or help.
 my chipset is Intel P67 on ASUS P8P67 Delux MOBO
  Confused: Why a VCR with TBC if separate TBC needed anyway?By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 20:31
  New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbcBy yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43
  TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GLBy m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36
  TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58
  panasonic VCR tbc + external tbc - any use ?By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
