Hi folks,
I just tried to upgrade from Format Factory 2.60 to 2.70 and during executing the .exe file (Installation) I got this ERROR saying ...
"Error Opening File For Writing" ... and got this
"C:\Program Files(x86)\FreeTime\FormatFactory\FFModules\Filter s\ffdshow\ffdshow.ax"
I tried several times ... finally I chose to ignore and skipped this file and the installation went fine then and completed.
Q: Did anyone else get this Installation "ERROR" and Why!?!?
Thanks,
G!![]()
Hi folks,
I got my answer from Chen ... so here it goes for the next person who might run into this installtion problem ...
1) Make sure you have None of you Media Players ... playing ... Close VLC or whatever you use.
2) Uninstall the Old Version first, then install the New version!
The install of Format Factory 2.70 worked perfectly.
G!
Installation of ffmpegX on os X.6 : error message
By Gruntosaure in forum ffmpegX general discussionReplies: 5Last Post: 22nd Dec 2010, 18:54 -
Installation error
By johnsonk in forum ffmpegX general discussionReplies: 2Last Post: 14th Aug 2009, 11:05 -
Installation Error In Leopard
By Lefty! in forum ffmpegX general discussionReplies: 3Last Post: 6th Dec 2008, 04:14 -
vegas 6.0 installation error
By scd250 in forum Software PlayingReplies: 3Last Post: 27th Feb 2008, 21:09 -
Installation error -
By ruggerjvd in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2007, 09:06
