I'm using a Canon Elura 100, which is your basic standard definition camcorder. In 4:3 mode, the DV files are 720x480 with a .889 pixel aspect ratio, producing a 4:3 display aspect ratio. Based on information provided here in the past, in the AVS file I crop 8 pixels off each side, and then resize the resulting 704x480 to 640x480. I understand that produces the exactly correct square pixel aspect ratio. I'm using Cedocida, Yadif and VirtualDubMod, if it matters.
But the camera also has a "wide" mode. The output from that is still 720x480, but now the PAR is 1.185, producing a display aspect ratio of 1.778 (i.e. - 16:9). So I'm wondering what the correct resize would be for DivX. Do I need to trim the sides before resizing? By how much?
Also, I remember from somewhere that resizing upward doesn't work very well. Is there a particular resizing plugin that would let me resize up to 852x480 with good quality? Or should I resize down to 720x404?
another option is to encode as is (720x480) and use aspect ratio flag in divx or xvid , or use mpeg4modifier
resizing to 848 or 854 /480 is fine. the problem with that type of cam and "widescreen" mode is that it uses the same single tiny ccd to capture more pixels. it may turn out a bit soft no matter how you encode it.
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
Wide screen
By breeze9 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2007, 23:31 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 13:41 -
wide screen
By ht0160 in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 17:52
