Loaded Panasonic encoder, done what you said in the email, flaskmpeg begins encoding and then stops at 7% each time. tried it about 3 times same stoppage time each time. Any ideas?
Your right, I looked at the small amount of movie that panasonic encoded and it is way better than BBMPEG.
there are alot of reasons for flask crashing. It is known to be buggie for some people.
If your not using version .594, I suggest you try that. It has been the better one for me.
See this download page http://www.digital-digest.com/dvd/downloads/flaskmpeg.html
Also, it's suggested that you restart Flask each time you use it. Instead of preview, stop, encode a second, stop, encode.
You can also try their forums http://www.delphi.com/n/main.asp?webtag=flaskmpeg&nav=start
That may shed some light.
Or, ask vitualis, I remember reading that he uses Flask.
