Hi everyone,
I was wonder if there is any bitrate limitation in terms of bitrate for a MKV file burned on DVD, which should be read from a stand alone BluRay player, which is supposed to play MKV file...
I supposed canonical 10Mbit (like DVD video) would be the answer... Is there any precise number?
Thank you in advance!
source: http://www.blu-ray.com/faq/#bluray_speedAccording to the Blu-ray Disc specification, 1x speed is defined as 36Mbps. However, as BD-ROM movies will require a 54Mbps data transfer rate the minimum speed we're expecting to see is 2x (72Mbps).
the combined bitrate your material needs for playback should be below the speed you want your drive to spin (normally the recommend vbv max fill rate (kbit/s) should be 24 000 for single and 40000 for double drive speed)
-> if you limit you vbv values accordingly 10MBit/s and even higher should not be a problem,.. -
40 Mbps is the Blu-ray max bitrate. From 'WHAT IS' Blu-ray to the upper left on this page. Which stand alone BD player do you have? I would check with that manufacturer to see what max MKV bitrate that unit can handle.
The BD discs I've converted to MKV and burned on DVD DL discs for backup seem to max out at about 12Mbps, so that would seem a good number. I couldn't use any higher bitrate as the movie wouldn't fit on DL media unless the playing time was much shorter. My backups are movie only. With extras, the bitrate would be quite a bit lower. The MKV at 12Mbps was 1hr 30 min. If you were using single sided DVD media, the bitrate would likely have to be about half that to fit.
Maximum Bitrate
By unity2 in forum Authoring (DVD)Replies: 17Last Post: 24th Jun 2011, 08:25 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 22:25 -
DVD rip to x264 using MKV while keeping maximum picture quality
By ryanfever in forum DVD RippingReplies: 5Last Post: 20th May 2009, 06:51 -
Check the Bitrate of mkv file
By maass in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 08:42 -
Maximum Safe Bitrate
By SCDVD in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2007, 23:37
