I have a lot of clips of motorcycling that I captured a few years back. They are uncompressed and in AVI format. YUY2 YUV packed 4:2:2. I can view them fine in kmplayer or any other player.
When I try to compress them using MS expression encoder, they just give a blank black screen with the audio. In Gspot i get this error showing:
Bad chunk in frame data: Invalid length
· Chunk: /RIFF:AVI
· Offset: 0x3efefff2
· Value:0x46464952
Multipart OpenDML AVI (2 parts)
(6750 frames in first part, 2670 frames follow)
Some of the clips that were captured in YVU9 have correct length and compress no problem.
Is there a software that can fix this minor error so I can have them compressed.
Oh forgot to mention, When I run a compressor like xilisoft and try to compress to wmv, it works fine. It compresses but I need to use expression encoder to use it pre-processing features such as crop.
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
Avi chunk viewer?- what is this?!
By vanjo in forum Software PlayingReplies: 21Last Post: 29th Oct 2010, 02:20 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 16:14 -
avi key frame error issue
By greendesert in forum Software PlayingReplies: 1Last Post: 8th Jul 2009, 12:06 -
avi chunk viewer
By agent222 in forum Video ConversionReplies: 5Last Post: 15th Nov 2007, 10:03
