    Feb 2008
    Portugal
    Hello, everyone.
    I'm working with Foxit. But I haven't access to some functionalities. I think it is because the book has in the title the word SECURED. What can I do to cancel that "word".
    Thanks for your help.
    Oct 2005
    666th portal
    if it's a pdf you can get password/security "removers"
    Feb 2008
    Portugal
    I received a book but I don't know any password. So I can't alter that situation?
    PS- Yes, it is a PDF document.
    Oct 2005
    666th portal
    google "How to Remove PDF Restrictions"
    i use an elcomsoft program.
  5. Anonymous
    Guest
    Maybe the settings prohibited the display of this book.
    In the program go to tools preferences and to trustmanager. remove the v to disable the trustmanager.
    If that doesn't help then there are build in restrictions in the pdf file and go on with aedipuss advice.
    Aug 2006
    You might also try this site:
    http://www.ensode.net/pdf-crack.jsf
    I used it a couple of years ago and it worked for me at the time. It's limited to PDFs smaller than 5Mb, though.
