Is this possible?
It would save me a lot of time whilst I am testing different things out.
in the render settings when you add to render queue, not in the comp . If you you do it in the comp, you have to trim the work area or make a nested comp
1) add to render queue. compositon=> add to render queue
2 ) there will be some hot text besides the module labelled "render settings" , click on that.
3) click on the button "custom" . Enter your start and endpoints
if you need some basic tutorials look at lynda.com , adobe.tv, and videocopilot.net has some free beginner tutorials as well -
Yes, go to Composition > Composition Settings > Start Time Code and set that to 0:00:00 and also set Duration to 0:00:10 and then press "OK". After Pre-render the video and you will get 10 Seconds of the video. I tried it and 2.5GB was used up just for that little 10s.
Hope this help.
After Effects rendering produce pixelated video...
By arminio in forum EditingReplies: 7Last Post: 10th Feb 2012, 10:44 -
Help in rendering in After Effects!
By surferadi96 in forum EditingReplies: 5Last Post: 29th Jan 2012, 12:36 -
Rendering Effects in Premiere CS3
By Cherbette in forum EditingReplies: 3Last Post: 21st Sep 2011, 00:47 -
FAST RENDERING of Final Cut Studio Pro and After Effects files.
By Kevin Whelan in forum MacReplies: 3Last Post: 24th Aug 2011, 12:40 -
2:30 minute video is 564 megs in size after rendering in Vegas
By Great Googly Moogly in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2010, 03:19
