Hi everyone,
I'm sure many of you know about the other threads I have started relating to an ongoing project to capture VHS to put on DVDs. Anyway, I have a very specific problem that I don't really understand and I am hoping someone can help me. I have captured video in Huffyuv AVI through the Panasonic AG-1970P source and Cypress TBC-100 Time Base Corrector with S-Video.
However, once I encode the video to Mpeg 2 the aspect ratio changes and the video appears vertically stretched a bit. I am setting it to encode with the aspect ratio of 4:3, which I assume is what VHS is, yet the video is distorted. I really prefer the original image and dimensions but I can't seem to preserve it once it is run through an encoder.
Is it possible that some VHS is not 4:3? Since I can only encode with 16:9 or 4:3 selected, what are my options to preserve the original dimensions of the footage? Should I encode with 16:9 but add borders on the left and right sides?
Here is what I am talking about:
http://imageshack.us/photo/my-images/829/vlcsnap2011070205h48m18.jpg/
This is from the original Huffyuv AVI of the captured footage
http://imageshack.us/photo/my-images/36/vlcsnap2011070205h48m40.jpg/
And this is the same frame from the encoded Mpeg 2 file
Can someone explain to me why the encoded video is stretched and has a different aspect ratio than the source? How do I fix this?
Thanks.
You took screenshots with VLC.
Your Huffy AVI video has no aspect ratio flags, thus is usually displayed as 1:1 in media players.
When you encode to MPEG2 and set the AR, a media player will "stretch" the content to the proper Display Aspect Ratio converting to square pixels when playing it back on a PC monitor
Notice the dimensions are 720x540 in that screenshot. 4/3 = 720/540 x 1/1
Look at the inner radius of the circle. Which looks more like a circle, which looks more like an oval ? Go to a frame that has a clearer picture of something like a tire or that life preserver
Some media players will display 4:3 content as 640x480 (which is also 4:3 when using square pixels)
change default aspect ratio without re-encoding?
By boonesmi in forum Video ConversionReplies: 14Last Post: 30th Aug 2012, 10:17 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 16:27 -
Modify aspect ratio without re-encoding (x264)
By MindBlank in forum Video ConversionReplies: 5Last Post: 29th May 2010, 09:50 -
Video Encoding - Issues With Aspect Ratio for WD HD TV Player
By Chopmeister in forum Video ConversionReplies: 0Last Post: 14th Mar 2010, 04:25 -
Change Aspect Ratio of .mp4 without re-encoding
By rtharagan in forum Video ConversionReplies: 9Last Post: 27th Jan 2010, 10:07
