Well I'm searching for a video and audio editing software...
I'm a retro lover and I synchronize the sound of old vhsrips with
japanese raws in order to preserve the old good times...
So far I had been using audacity for the audio editing,windows media
player for synchronizing the sound with raw and virtualdub for the encoding...
The result isn't what I expected though...
There were many sound quality issues and the irritating fssssss(from old vhs despite having removed the noise)
So I'm currently searching for a program/s that will do the following:
-sound editing(with a good noise removal filter and if it is possible able to extract the sound with the least quality loss)
-video editing for the whole synchronizing process(with playback)
-encoding program
I have heard about a few programs that do the job but having not tried them myself I am kind of unsure...
I'm certain that the best program for encoding is Megui...
For the video editing I have two friends who do the same task,the one is using Sony Vegas and the other one Cyberlink powerdirector(from what I've heard ulead is not half bad either...)
For the audio editing I have heard of adobe audition and cool edit pro...
If it is possible I would prefer easy-to-use programs(what I call noob friendly...)
I don't have a problem using a more advanced program though if it is for the name of quality(coughs arrogantly) but I don't want to have my efforts wasted...
Thanks in advance...
PS:If there is a similar thread then then do merge it,I don't have any issues here...
	Vegas Pro has strong audio capabilities, and supports .VST plugins, don't know about the "studio" versions. .VST plugins are filters for audio and work similar to VirtualDub video filters. They can be chained.
 Anything that uses .VST plugins is what you need, most are free.
	Call me pedantic (or worse  ) if you like, but it's just "VST" (no dot). ) if you like, but it's just "VST" (no dot).
 Virtual Studio Technology
	Anyone knows if Vegas is kind of handy??
 If I'm not mistaken the whole audio editing will actually be the synchronized audio with the appropriate filters,right??
 Well,since there are japanese dvd and blue rays available I was thinking that I could adjust the vhs sound into the raw(like a friend of mine suggested) with adobe audition however that seems quite difficult and complex to me right now(maybe cause I haven't tried it yet)...
 Any ideas or suggestions??Last edited by Raziel; 2nd Jul 2011 at 21:26.
  synchronizing video and audio in a remuxed MKSBy wsw70 in forum Video ConversionReplies: 0Last Post: 18th Jul 2011, 07:37
  synchronizing an new audio stream on a video fileBy gouletjo in forum Authoring (DVD)Replies: 5Last Post: 15th Feb 2010, 19:47
  Synchronizing video and audio...? Best way?By massimou in forum EditingReplies: 1Last Post: 4th Aug 2008, 13:43
  Problem synchronizing audio and videoBy weareone in forum Newbie / General discussionsReplies: 11Last Post: 20th Mar 2008, 19:20
  Synchronizing audio/video with FFMPEGBy beyondthegrave in forum EditingReplies: 2Last Post: 13th Nov 2007, 09:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
