Hi Friends,
I wanted to know, which is the best software that can be used for converting HD video Clips in .MOV format to MP4, that will ensure minimum quality loss if atall there has to happen any? (Since it is a HD Video, My source only allows me to download the videos in .MOV format cant change it, I can only change it once it is downloaded on my PC in .Mov Format) I have used Handbrake but is there anything better than it which will ensure minium loss in quality and maintain the HD Quality like the original Video clip.
Thanks in Advance.
Results 1 to 11 of 11
Try remultiplex it with mymp4boxgui, open the mov, save as a new mp4. No quality loss.
What does remultiplex means ? And How do I run it I have installed mymp4boxgui on my desktop when I load the app I see 4 tabs
1. MUX
2. DEMUX
3. JOIN
4. SPLIT
I believe to convert this HD Video file from .MOV to MP4 I have to click on the MUX tab then I see "Add", "Remove", "CLEAR" so I add the file from my PC location and I click, save as, when I am done, nothing happens !! What am I missing ?
is it better than Handbrake ?Last edited by augustya; 2nd Jul 2011 at 05:26. Reason: edit
You can do this easily with Mpeg StreamClip. Just import your .MOV and then "Save AS" .mp4. This will simply re-wrap the video and audio into new container. No quality loss and should complete in a few seconds.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I know there would be lot many but which is the best between al these Handbrake, mymp4boxgui and Mpeg StreamClip ?
mymp4boxgui or mpegstreamclip as they do not reconvert the video and audio.
Ok, When I convert the video to MP4 using mymp4boxgui and when I try to play the video using Real Player it does not play and gives a message cannot start playback but when I open it with VLC it does play. Why does it not play with Real player that is my default player.
The Video that I convert to MP4 using mymp4boxgui does not play with Real Player. Any particular reason why does it not play with Realplayer?
Sweet! I used Mpeg StreamClip and it worked in like 2 seconds. Love this site. Thank you all.
When man discovered milk came from cows, what did he THINK he was doing?
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 10:27 -
Multiple Language Conversion mov or mp4
By Tseng61 in forum Video ConversionReplies: 1Last Post: 19th Sep 2010, 03:57 -
Video Converting HD 720p .mov to .mp4?
By jamorama in forum Video ConversionReplies: 4Last Post: 18th Jun 2010, 13:37 -
Having trouble with a conversion (mp4 / avi / mov / flv)
By loxley in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 11:17 -
Converting video of any format to MOV or MP4 Linux/Debian
By lordshadow in forum Newbie / General discussionsReplies: 11Last Post: 31st Aug 2008, 10:35
