Hi. Having checked Videolan's webpage it seems VLC should be capable of playing MKV files. Indeed, many people use VLC as it 'can play anything'. Can anyone suggest a reason why I'm only getting audio when playing this file? (It was originally in a different format but the AR was wrong so I used Solveig to convert.)
Many thanks.
Format : Matroska
File size : 184 MiB
Duration : 5mn 51s
Overall bit rate : 4 399 Kbps
Writing application : SolveigMM Matroska Muxer Version 1.0.1012.29
Writing library : libmatroska 1.1.0
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=24
Codec ID : V_MPEG4/ISO/AVC
Duration : 5mn 51s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : PCM
Codec ID : A_PCM/INT/LIT
Duration : 5mn 51s
Bit rate mode : Constant
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : 31ms
Language : English
I guess it didn't play before you used solveig to change AR?
You could also try an older version of VLC, https://www.videohelp.com/tools/VLC_media_player/old-versions#download -
That, I do not know - my previous player was GOM. I've recently re-installed Windows and I'm trying to have as few players/codecs installed as possible. But it looks like I'll need a third to go with WMP and VLC. It'll be either KMP or POT (assuming POT has the ability to act as a 'recorder' in the same way as KMP. Should do, it's the same developer who's behind it.)
Thanks, Baldrick.
VLC not playing mkv(720p, h264) files smoothly?
By swalih in forum Newbie / General discussionsReplies: 15Last Post: 9th Mar 2012, 19:31 -
MKV files suddenly not playing properly on VLC
By thekenoshakid in forum Newbie / General discussionsReplies: 5Last Post: 5th Dec 2011, 23:24 -
VLC not playing MKV
By stringcheesy in forum Software PlayingReplies: 1Last Post: 19th Mar 2011, 03:29 -
VLC player not playing MKV file
By GLE3 in forum Software PlayingReplies: 3Last Post: 15th Feb 2009, 15:39 -
Best Aspect Ratio playing .mkv video via VLC/Quicktime for viewing on HDTV
By iMacMan in forum MacReplies: 4Last Post: 19th Feb 2008, 01:04
