Afternoon all.
Just a quick question, I'm looking for some Star Wars sample clips, like
from the PHantom Manece, etc.
I did a VHS capture of some scenes and I want to see how they compare
to mine (SVCD, or even VCD)
I've already seen one in VCD but didn't like how narrow it was, but it was
a start.
so, any clips on above Star Wars would be really appreciated.
I also have Cute FTP if that helps, and I'm not concirned with file size.
Thanks so much for all your support!
-vhelp
hey you should be able to change the size if its too narrow, look in your options and there should be other choices
bruce,
nah, you got me all wrong here
I was just looking for some samples. I'm fairly confident in the
aspect ration thing and all that stuff. And I wasn't having trouble
trying to convert it either, as I was not do such.
Anyways, I only wanted to see if anyone has done it (any) yet here
on the "Star Wars - Phantom Menace", that's all, ...not big deal
And they (clips) can be other DVD movies too.
I've have greate success with using Cute FTP and all with other
sites I visited. In fact, i remember D/L'ing a sample clip from
[Kdiddy] but the clip/file came out garbled (square blocks, and it
would hang my system) I had systems problems, but all are fine now.
Kdiddy, i found your PM to me, and found your sample clip FTP link,
but it doesn't seem to be wrking. I keep trying (randomly) So, if
you get a bunch of knocking, it's only me
I was so curious to know what this clip was, but never got a chance
to find out. Maybe this itme, your FTP and my system will shake
hand clean, he he... Thanks K.
Oh, I also got the Matrix, case anyone is wondering. If you have
any scenes here to discuss (blocks, or hard to enc., etc. ) maybe
you could warn me as I'm going to be playing around with this DVD. (kmart $19 / walmart $16<-- )
Well, if you have any link or ftp addr's, I'll keep a look out.
As always, thanks for all your support, peoples.
-vhelp
Premiere and sample rates
By tpapictures in forum EditingReplies: 6Last Post: 4th Apr 2011, 20:05 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
SDK sample codes.
By suefyzah in forum Capturing and VCRReplies: 7Last Post: 29th Jul 2008, 22:12 -
archos 404 bullet sample clips
By nivek_nayr in forum Portable VideoReplies: 0Last Post: 20th Feb 2008, 01:36
