Can someone recommend a fairly easy way (with free tool if possible) to convert FLV video (with AVC / AAC codecs, from Youtube) into a DVD-ready MPG file?
The only thing I have now that can read the FLV is Avidemux, but with that I have to convert to AVI first then encode after that. Is there anything simpler? Thanks.
Hi Beavis,
Try Freemake Video Converter. It'll read .flv & transcode to MPG. It'll also burn them straight to DVD, but I'm not sure if the DVD's are standalone DVD player compliant. -
I have been using this great tool http://www.any-video-converter.com/products/for_video_free/
I need an EASY program to edit things out of .flv files
By J Tinsby in forum Video ConversionReplies: 6Last Post: 28th Jun 2011, 04:07 -
Is there a free and easy to use editor for FLV files?
By MJ in forum EditingReplies: 1Last Post: 1st Apr 2011, 02:10 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 23:09 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 21:35 -
Best container & codec for FLV conversion to DVD
By Dsypher in forum Video ConversionReplies: 12Last Post: 21st Aug 2007, 15:53
