Hello
I REALLY really need help with this problem.
I have create a SVCD movie using frameserving in VirtualDub 2 TMPGEnc but the problem is that i have the movie but no sound... Can any one give me a tip to how to join the sound with the movie in a fast way?
I have make a lot of SVCDs and this is the first time
ANY one please
Get the wave file out using VirtualDub.
Encode it using TMPGENc System (audio only) at 224 kbs Stereo.
Use TMPGEnc Mpeg tools (file menu) to:
Demultiplex and get the video file (.mv2)
Multiplex the video (.mv2) and the newly encoded sound using SuperVideoCD (VBR).
This should do it. -
Originally Posted by FranckV
I'm not consiering to have two audio tracks but onlu one ...
Giuliano -
I am not Frame Serving.
Sometimes, when saving as AVI from VirtualDub before encoding with TMPGENc, it happened to me too. I have to save as segmented AVI to fix the issue.
You already have encoded the video so you just need to re-encode the sound unless you want to redo everything from the beginning.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
