I have been trying to convert fraps footage and get it on the dam final cut pro timepline in osx. mission impossible it seems, virtual dub helps with saving to the old style avi.
But its so frustrating, I was told ffmpegx was the saving grace... nope. When trying to convert the AVI to DV so I can use it i get this error :
Encoding started on Thu Jun 30 13:11:26 BST 2011
Input #0, avi, from '/Volumes/mac/FrapsConverted/ArmA2OA 2011-06-27 19-29-30-97.00.avi':
Duration: 00:00:20.2, start: 0.000000, bitrate: 374300 kb/s
Stream #0.0: Video: rawvideo, yuv420p, 960x540, 29.97 fps
Stream #0.1: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
Output #0, dv, to '/Users/hello/Desktop/FromMMPegx.dv':
Stream #0.0: Video: dvvideo, 960x540, 29.97 fps, q=2-15, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[dv @ 0x399490]Can't initialize DV format!
Make sure that you supply exactly two streams:
video: 25fps or 29.97fps, audio: 2ch/48Khz/PCM
Could not write header for output file #0 (incorrect codec parameters ?)
bench: utime=0.013s
Encoding completed on Thu Jun 30 13:11:26 BST 2011
Looks like there is no support for the fraps codec?
Can anybody help me, PC vs MAC i thought those days were over.
Closed Thread
oOParaOo, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Continue in:
https://forum.videohelp.com/threads/336473-Fraps-Fraps-Fraps-!!!!
Moderator redwudz
Trouble With FRAPS
By Auroraah in forum Capturing and VCRReplies: 0Last Post: 21st Jan 2012, 13:48 -
Fraps Fraps Fraps !!!!
By oOParaOo in forum ffmpegX general discussionReplies: 3Last Post: 30th Jun 2011, 18:02 -
fraps
By krohm in forum Capturing and VCRReplies: 16Last Post: 30th May 2011, 21:43 -
Fraps Capture
By wulf109 in forum Capturing and VCRReplies: 1Last Post: 17th Dec 2010, 04:58 -
Fraps on MAC
By Smoogle in forum ffmpegX general discussionReplies: 2Last Post: 4th May 2007, 23:40
