I have been trying to convert fraps footage and get it on the dam final cut pro timepline in osx. mission impossible it seems, virtual dub helps with saving to the old style avi.
But its so frustrating, I was told ffmpegx was the saving grace... nope. When trying to convert the AVI to DV so I can use it i get this error :
Encoding started on Thu Jun 30 13:11:26 BST 2011
Input #0, avi, from '/Volumes/mac/FrapsConverted/ArmA2OA 2011-06-27 19-29-30-97.00.avi':
Duration: 00:00:20.2, start: 0.000000, bitrate: 374300 kb/s
Stream #0.0: Video: rawvideo, yuv420p, 960x540, 29.97 fps
Stream #0.1: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
Output #0, dv, to '/Users/hello/Desktop/FromMMPegx.dv':
Stream #0.0: Video: dvvideo, 960x540, 29.97 fps, q=2-15, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[dv @ 0x399490]Can't initialize DV format!
Make sure that you supply exactly two streams:
video: 25fps or 29.97fps, audio: 2ch/48Khz/PCM
Could not write header for output file #0 (incorrect codec parameters ?)
bench: utime=0.013s
Encoding completed on Thu Jun 30 13:11:26 BST 2011
Looks like there is no support for the fraps codec?
Can anybody help me, PC vs MAC i thought those days were over.
	So what format should I convert? use virtualdub? dont bother? what setting to get bloody fraps on the mac timeline is so dam frustrating fraps uses a codec no body can bloody use, rip off.
  Fraps is doing my head in/By oOParaOo in forum Video ConversionReplies: 1Last Post: 30th Jun 2011, 08:19
  frapsBy krohm in forum Capturing and VCRReplies: 16Last Post: 30th May 2011, 21:43
  Fraps CaptureBy wulf109 in forum Capturing and VCRReplies: 1Last Post: 17th Dec 2010, 04:58
  FRAPS lagging!!!By LoveMyslf in forum Video Streaming DownloadingReplies: 7Last Post: 8th Nov 2008, 15:35
  Fraps on MACBy Smoogle in forum ffmpegX general discussionReplies: 2Last Post: 4th May 2007, 23:40
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
