Trying to convert an mkv file to a format that runs on my panasonic tv. Completes successfully, and video is detected and plays, but the video is out of sync of the video.
Here are the details:
Original (mediainfo):
General
Unique ID : 199716239153927950110135018103473951927 (0x963FF2D34D051762AC0B23B46987D4B7) Complete name : myvideo.mkv Format : Matroska File size : 6.54 GiB Duration : 2h 16mn Overall bit rate : 6 835 Kbps Movie name : myvideo Encoded date : UTC 2011-06-28 08:52:44 Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58 Writing library : libebml v1.2.0 + libmatroska v1.1.0 Cover : Yes / Yes / Yes
Video
ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Format settings, GOP : N=1 Muxing mode : Header stripping Codec ID : V_MPEG4/ISO/AVC Duration : 2h 16mn Bit rate : 5 326 Kbps Width : 1 280 pixels Height : 534 pixels Display aspect ratio : 2.35:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.325 Stream size : 4.96 GiB (76%) Writing library : x264 core 61 r965M 3d2983d Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=0.8:0.8 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-4 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5326 / ratetol=1.0 / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.70 Language : English
Audio
ID : 2 Format : DTS Format/Info : Digital Theater Systems Muxing mode : Header stripping Codec ID : A_DTS Duration : 2h 16mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 1.44 GiB (22%) Language : English
multiAVCHD Log:
[20:54:40] Initialising...
[20:54:40] Checking for new version...
[20:54:41] You have the latest build.
[20:54:41] Consistency check finished!
[20:54:41] Initialization finished. multiAVCHD is ready!
[20:54:41] 2 years and 186 days since multiAVCHD was published.
[20:54:41] 450 people supported it with donations
[20:54:41] and you are the 140825 one to launch the program...
[20:54:41] Support multiAVCHD to extend its features and keep it going!
[20:54:41] multiAVCHD.dat version: [04010767]
[20:55:20] Checking for available space and drive types (FAT32/NTFS)...
[20:55:21] Destination [c:]: NTFS, 776341.9 MiB (758.146 GiB) free space
[20:55:21] Temp folder [c:]: NTFS, 776341.9 MiB (758.146 GiB) free space
[20:55:21] Log started for multiAVCHD v4.1 (build 770)
[20:55:21] Selected output mode: Panasonic Viera TV / Camcoder (SDHC) (PAL)
[20:55:21] Processing one title...
[20:55:21] Existing c:\Users\Daniel\Desktop\Videos\AVCHD\ cannot be used as destination folder!
[20:55:21] Output will be written to: c:\Users\Daniel\Desktop\Videos\AVCHD-20110630-205521
[20:55:21] Processing (myvideo.mkv)...
[20:55:21] This title is marked for reencoding / uncropping...
[20:55:21] Encoding process may take 10 min to 10 hours, so be patient...
[20:55:21] *** Initiating video encoding:
[20:55:21] *** Original : 1280x534
[20:55:21] *** Crop : 0
[20:55:21] *** Resize : 1280x720
[20:55:21] *** Uncrop to : 1280x720
[20:55:21] *** Sharpen : 0
[20:55:21] *** Bitrate : 5190 kbps
[20:55:21] *** Frame rate: Original (23.976)
[20:55:21] *** Level : 4
[20:55:21] *** Quality : One pass (insane)
[20:55:21] *** SAR : 1:1
[20:55:21] *** DAR : 1280x720
[20:55:21] *** Profile : Blu-ray
[20:55:21] *** Encoding : One pass - content: [02:16:49]
[20:55:21] *** Encoding : x264 options: --preset ultrafast -B 5190 -I 48 --level 4 -i 24 -b 3 -m 0 -r 4 --ipratio 1.4 --vbv-bufsize 15000 --vbv-maxrate 14000 --qcomp 0.5 --threads auto --thread-input --aud --nal-hrd vbr --sar 1:1 --me dia --b-pyramid strict --slices 0 --weightp 0 --rc-lookahead 0 -o "myvideo.[1280x720-23.976].264" "c:\multiAVCHD\_TEMP\multiTEMP-20110630\20110630-205521-uncrop-running.avs"
[21:21:56] *** Speed : 123.4 fps (elapsed: 00:26:35 - Realtime x 5.15)
[21:21:56] *** Transcoding successful!
[21:21:57] Detected frame reference count: 3 (max:6).
[21:21:57] Detected video: ID#0:V_MPEG4/ISO/AVC 1280x720, fps=23.976, ref=3
[21:21:57] Detected audio: ID#2:A_DTS (48000Hz 24bit 6ch 1472kbps) Language: und
[21:21:57] PAL speedup will be applied to all streams for Viera PAL compatibility!
[21:21:57] Attempting to convert A_DTS audio track #2...
[21:21:57] Encoding A_DTS to AC3...
[21:21:58] Parsing to NicAudio/aften (avisynth)...
[21:21:58] Extracting audio track #2 (mkvextract)...
[21:27:25] Audio encoded to AC3 successfully!
[21:27:25] Added audio: A_AC3, "myvideo (1).mkv.t2.und.ac3-aft.ac3", lang=und
[21:27:25] M2TS stream split set at 4000MiB...
[21:27:25] Creating clip and playlist info (tsMuxeR)...
tsMuxeR (Version 1.10.6) output:
Decoding H264 stream (track 1): Profile: Main@4.0 Resolution: 1280:720p Frame rate: 23.9761
H.264 manual setted fps not equal stream fps. Change H.264 fps from 23.9761 to 25
Decoding AC3 stream (track 2): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6
B-pyramid level 1 detected. Shift DTS to 2 frames
H264 bitstream changed: insert SPS/PPS units
Processed 197032 video frames
Creation of Blu-ray playlist
Creation of Blu-ray stream info and seek index
Mux successful complete.
Muxing time: 2 min 54 sec
tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --split-size=4000MiB --vbv-len=500
V_MPEG4/ISO/AVC, "myvideo (1).[1280x720-23.976].264", insertSEI, contSPS, lang=eng, fps=25.000
A_AC3, "c:\multiavchd\_temp\multitemp-20110630\myvideo (1).mkv.t2.und.ac3-aft.ac3", lang=und
[21:30:17] Media transfer: 00000 -> 00000.m2ts
[21:30:17] Media transfer: 00001 -> 00001.m2ts
[21:30:17] Processing playlist...
[21:30:17] Title #1 added: "myvideo"
[21:30:17] Verifying title...
[21:30:21] Title has: 1 audio tracks and 0 subtitle tracks
[21:30:21] Preparing authoring information...
[21:30:21] Authoring menu (PAL).
[21:30:21] Creating title thumbnails for 1 titles (XMB)...
[21:30:26] Using 1 thumbnail/chapter links for title #1...
[21:30:26] *** Extracting 1 chapter thumbnails...
[21:30:26] *** Chapter #1 [00:00:00.000] set for thumbnail at [01:08:24.791]
[21:30:28] Image processing for XMB menu completed!
[21:30:29] Setting main menu for 1 titles...
[21:30:29] Playback will start with title #1 (myvideo).
[21:30:29] Setting menu properties...
[21:30:29] Processing clip (CPI/CLPI) files...
[21:30:29] Completed.
[21:30:29] Applying Panasonic SDHC for TV parameters...
[21:30:29] Preparing AVCHDTN database...
[21:30:29] Database and index created!
[21:30:29] Setting FAT compatible 8.3 filenames...
[21:30:29] Done!
[21:30:29] Saving multiAVCHD quick-load project (mpf):
[21:30:29] c:\Users\Daniel\Desktop\Videos\AVCHD-20110630-205521\multiAVCHD.mpf (OK!)
Compilation summary:
Format: Panasonic Viera TV / Camcoder (SDHC) (PAL)
1. myvideo [02:16:57]
Overall duration : 02:16:57
Output size : 6044 MiB (5.902 GiB)
[21:30:29] c:\Users\Daniel\Desktop\Videos\AVCHD-20110630-205521 folder created (AVCHD/Blu-ray output)!
[21:30:29] Copy c:\Users\Daniel\Desktop\Videos\AVCHD-20110630-205521 to X:\PRIVATE\ of SDHC/SD/MMC card.
[21:30:29] or SD_VIDEO and PRIVATE to root of your SDHC/SD/MMC card.
[21:30:31] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20110630\).
[21:30:31] Your compilation contains 2hrs 16min 57sec of video material.
[21:30:31] multiAVCHD finished in 2109.539 seconds (00:35:09.538)!
[21:30:31] End of log.
Any help would be greatly appreciated
you converted from 24 to 25fps and it's sometimes a problem. try leaving it 24fps.
I'm not sure how to do that with multiavchd, i usually just leave the default settings as they are. Except for the size and number of passes.
In the multiavchd author tab look to the right under general-tv system and switch from pal to ntsc there.
I have a PAL tv.
If you guys were looking at the line "H.264 manual setted fps not equal stream fps. Change H.264 fps from 23.9761 to 25", i've transcoded videos before with that and they've come out fine. -
Sounds like you downloaded a video that wasn't encoded properly causing the audio to go out of sync,there a lot of threads related to this type of problem,the 23.9761 need to have the audio shrunk a bit when the fps are matched to 23.976 and authoring to pal will still have that issue to deal with.
Do you know any way to do that with multiavchd or other free software? (higher quality the better)
EDIT: I used mkv2vfr on it, and the timecode file just had:
Does that mean its not vbr?Code:# timecode format v1 Assume 23.976 0,197029,23.9760
What should i do now?Last edited by dan_man555; 1st Jul 2011 at 00:31.
Problem with multiAVCHD...
By hiimbored in forum Authoring (Blu-ray)Replies: 7Last Post: 2nd Jun 2015, 11:14 -
multiAVCHD menu problem
By Clydesdale in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2013, 23:36 -
MultiavcHD menu problem...HELP!
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 07:06 -
multiAVCHD problem
By obadvw in forum Authoring (Blu-ray)Replies: 2Last Post: 17th Nov 2011, 17:02 -
Is multiavchd a problem?
By volam1 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Oct 2009, 16:19
