Hello,
I was wondering if anyone has tried a System Reset on their LaCinema Classic HD. According to the manual http://www.lacie.com/download/manual/lacinema_classic_hd_en.pdf in section 10.5.7 "This feature allows you to reset the product to its factory defaults, erasing all files and reverting all settings"
Does anyone know if that is correct that a System Reset actually erases the contents of the HD? or does it simply reset the settings of the device to factory defaults leaving the data on the HD untouched? The manual seems to say everything is erased. However, I had read elsewhere that it does not affect the disk contents (unfortunately you have to be able to read French - http://www.homecinema-fr.com/forum/viewtopic.php?f=1182&t=29932238&start=195 - Google translate doesn't work so well on it).
If you invoke the command on the device it says "System Reset: Are you sure you want to restore LaCinema Classic HD to factory settings?" . Not 100% convinced either way if that means it will completely erase the HD. I've cancelled out of that because I don't want to have to reload the HD with all the data I've put on there. So I'm wondering if anyone out there knows what the scoop is from actually doing it.
Results 1 to 1 of 1
AnonymousGuest
Lacie lacinema classic hd won't upgrade firmware
By GadgetLover in forum Media Center PC / MediaCentersReplies: 4Last Post: 28th Jan 2012, 21:55 -
LaCie Lacinema Classic 1TB won't play video
By mike_cd1982 in forum Newbie / General discussionsReplies: 56Last Post: 13th Jan 2012, 13:47 -
How do I reset video settings on my Lacie LaCinema Classic drive???
By neilharris76 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2011, 19:25 -
Problems with Lacie Lacinema Classic
By otinimeg in forum Newbie / General discussionsReplies: 21Last Post: 12th Mar 2011, 19:44 -
Lacie LACinema Classic HD - 1T
By AN11211 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2010, 13:25
