Results 1 to 11 of 11
  1. Hi,
    Does anyone know why movies would load slow in IE but not in Firefox on Mac and PC and on Safari? For example, I am trying to play this movie. It takes maybe 10-15sec to start playing in Safari and Firefox, it takes about 2-3min to start in IE (tested 8 and 9). I tried different computers and sometimes IE will launch an external player and on another computer it will try to play in the browser. In the browser it is very slow and there is nothing happening while you wait for the movie to load so you might think that it's not working but after 2-3 min it will play. Anyone has any idea what causes this behavior? I would appreciate any help.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by tarsierspectral View Post
    Hi,
    Probably related to your installation of Quicktime for Windows. I tried to compare IE9 to current Firefox to current Safari all on the same Win7 PC. Firefox took about 30 seconds to play. IE and Safari never opened the mp4 Quicktime file.
    http://www.kiva.org/about
  3. Originally Posted by edDV View Post
    Hi,
    hmm, but why would it universally be slow on all computers in IE? On some computers IE will launch Windows Media Player and play the file just fine. This is just H.264 mp4 file, why do you consider it to be Quicktime mp4?
  4. Member edDV's Avatar
    Mar 2004
    Hi,
    Well, Firefox launched the Quicktime viewer. The "free" Quicktime viewer doesn't identify the codec. It buffered like a Quicktime file.
    Do you know the codec used?
  5. Originally Posted by eddv View Post
    hi,
    does anyone know why movies would load slow in ie but not in firefox on mac and pc and on safari? For example, i am trying to play this movie. It takes maybe 10-15sec to start playing in safari and firefox, it takes about 2-3min to start in ie (tested 8 and 9). I tried different computers and sometimes ie will launch an external player and on another computer it will try to play in the browser. In the browser it is very slow and there is nothing happening while you wait for the movie to load so you might think that it's not working but after 2-3 min it will play. Anyone has any idea what causes this behavior? I would appreciate any help.
    probably related to your installation of quicktime for windows. I tried to compare ie9 to current firefox to current safari all on the same win7 pc. Firefox took about 30 seconds to play. Ie and safari never opened the mp4 quicktime file.
    hmm, but why would it universally be slow on all computers in ie? On some computers ie will launch windows media player and play the file just fine. This is just h.264 mp4 file, why do you consider it to be quicktime mp4?
    well, firefox launched the quicktime viewer. The "free" quicktime viewer doesn't identify the codec. It buffered like a quicktime file.
    h264.
  6. Member edDV's Avatar
    Mar 2004
    Are you the author of this site?
    If so, the player associated with *.mp4 depends on user settings in the browser. Most have no default for *.mp4 so it usually comes down to the last player plug-in loaded unless the user edits associations.
    I'm still wondering why Safari wouldn't play it.
  7. Member edDV's Avatar
    Mar 2004
    I did a "save link as" and downloaded the full file. Mediainfo shows
    General
    Complete name : D:\03022011_Appadurai.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 431 MiB
    Duration : 1h 17mn
    Overall bit rate : 782 Kbps
    Encoded date : UTC 2011-03-05 20:57:22
    Tagged date : UTC 2011-03-05 20:57:38
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Duration : 1h 17mn
    Bit rate mode : Variable
    Bit rate : 605 Kbps
    Width : 640 pixels
    Height : 360 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.088
    Stream size : 333 MiB (77%)
    Language : English
    Encoded date : UTC 2011-03-05 20:56:58
    Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 17mn
    Bit rate mode : Constant
    Bit rate : 96.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 51.9 MiB (12%)
    Language : English
    Others may have opinions on browser players.
  8. Originally Posted by edDV View Post
    Every Safari I tried it on plays the file fine. I am not the author of the site. I did make the video though.
    So the question still remains why is it slow in one browser and not the others?
  9. Originally Posted by edDV View Post
    General
    Format : MPEG-4
    Codec ID : mp42
    File size : 431 MiB
    Duration : 1h 17mn
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 1h 17mn
    Bit rate : 605 Kbps
    Width : 640 pixels
    Height : 360 pixels
    Color space : YUV
    Bit depth : 8 bits
    Language : English
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 17mn
    Language : English
    So should this play in any player/browser? Looks pretty "standard" to me
  10. You would have more control if you or the webmaster embedded a flash plyer in an html page - it would play on virtually any platform or browser immediately, instead of acting inconsistently on differently configured systems
    (very old systems, that can't handle youtube, or flash player 9+ won't be able to play it)
  11. Originally Posted by poisondeathray View Post
    Thanks. Where can I get the flash player to embed? Can I have 1 player for multiple videos? Or do I have to have a separate player for each? Will an iPad be able to play the videos in that case?
