I am using my AverMedia to capture TV and the output to MPEG-2 is producing rather low audio. The other outputs do not produce the low audio. I would like to use MPEG-2 because it is easy to remove the commercials in VideoReDo. Is there any suggestions on how to fix my audio issue? Thanks.
And when I drop the gloves I drop them for you - Matt Johnson
Capture TV from an analog feed of some kind, or over the air digital ATSC? If it's over the air,
the capture merely saves the incoming digital feed. If it's analog and the card is doing the conversion, look to see
if there is anything in the capture utility related to audio adjustment. If not, you'll have to re-encode the audio after the fact. -
I think your only option is to amplify the audio after the fact, unless you can find an option on the sat box to boost the volume.
I do find it interesting that you say AVI is louder... For me it's quite low even with AVI, but that's just because the source has a large dynamic range.
Need Original Drivers for Avermedia AverTV HD DVR (c027)
By Cam94Z28 in forum Capturing and VCRReplies: 189Last Post: 30th May 2023, 20:42 -
Why Low Audio With Screen Capture Video
By toubyw in forum Video ConversionReplies: 1Last Post: 13th Nov 2011, 15:17 -
Avermedia capture HD using firewire?
By Zachash in forum Capturing and VCRReplies: 3Last Post: 7th Jul 2011, 16:49 -
Help watching tv on Avermedia HD DVR capture card
By mason dixon in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2011, 12:00 -
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59
