Hi, everyone.
As the title suggests I'm using mkvtoolnix to add a .idx/.sub to my MKV file container, as it's the only way I can get the .sub to play on my Samsung TV (at least, I hope that'll play them). Anyway, my question is: is it possible to simply add the subs to the container and "mux" it without having to make a brand new copy of the MKV file?
The problem is, if the file is already, say, 12GB, you need another 12GB free for the new copy with the added subs. It can take a while on external HD's and such as well.
I've tried several times to do just that (overwrite existing copy, append file instead of add, etc) but couldn't get it to work.
If it is impossible, can anybody say why, as I'm curious.
Thanks!
Nope, there's no tool that allows 'in-place' modification of mkv tools.is it possible to simply add the subs to the container and "mux" it without having to make a brand new copy of the MKV file?
It's not impossible to write an application that can to 'in-place' modifications, but it's really complicated and I doubt any one is writing such an application in the near future. If you want a more detailed explanation why it's complicated, you should read the mkv specs and think on how it could be done,...If it is impossible, can anybody say why, as I'm curious.
Cu Selur
H264+AC3 (MKV container) to H264+MP3 (MKV container)
By diebri in forum Video ConversionReplies: 3Last Post: 19th Oct 2011, 07:19 -
Adding subtitles to MKV file
By drgt in forum Newbie / General discussionsReplies: 8Last Post: 29th Dec 2010, 11:04 -
MKVToolnix muxing problem when adding or removing audio and subtitles
By firstliight in forum Video ConversionReplies: 1Last Post: 19th Nov 2010, 09:23 -
change an MKV container to AVI container???
By Spdngblt56 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2010, 22:23 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 19:19
