My HDTV displays message "no signal" after I connected my PC to it. I need to use VGA cable from and to - I don't have HDTV service.
http://www.kiva.org/about -
Be sure to set the resolution to something that is supported by the TV. If you don't know what the TV supports try 1024x760 at 60 Hz. Make sure the computer has enabled the VGA port. With the TV and the computer off connect the two with the VGA cable. Turn on the TV, then turn on the computer. The computer should then see the TV is connected to the VGA port and you'll be able to enable the VGA port manually if it isn't automatically enabled.
Connecting PC To HDTV Newb Question
By pr0bation in forum Newbie / General discussionsReplies: 14Last Post: 14th Dec 2010, 18:29 -
Newbie question, connecting speakers to A/V receiver
By mordeckai in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2010, 17:31 -
Help in connecting my pc to hdtv
By odedne in forum DVB / IPTVReplies: 15Last Post: 1st May 2008, 00:29 -
Black Intensity HDMI connecting question to HDTV/360.
By bradyfan123 in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2008, 12:49 -
Help Connecting My PC to my HDTV!
By Jeremy_bk in forum DVB / IPTVReplies: 26Last Post: 20th Dec 2007, 16:25
